engine installation - Ford Truck Enthusiasts Forums
engine installation
Old 06-11-2005, 11:15 PM
Andy Eppink Andy Eppink is offline
Andy Eppink is starting off with a positive reputation.
engine installation
I want to get an F-250 or 350 (< 10 years old, in good shape), 4wd with a bad or no engine (paper, wrecking yards, etc.) and install a small turbo diesel (or turbocompounded engine if I can find one) for better mileage, even if I have to suffer a huge loss in performance (creeping uphill in low gears @ 15 mph doesn't bother me a bit) so as to achieve good fuel mileage. It makes no sense whatever to me to run a big engine fully loaded say ~ 5% of the time and running at part engine load the rest of the time with the resulting terrible mileage (say ~ 20 mpg, should be able to do much better). To that end I've been looking thru the Internet for pickup power, speed, load, torque, rpm requirements, data, graphs, curves etc. so as to determine level ground, no wind, highway speed, fully loaded power requirements with no success (Ford website, SAE, etc. - no luck). Can anyone steer me in the right direction to find some of this? It's not arcane, proprietary knowlege I wouldn't think, just regular, basic stuff.
Thx.
Andy Eppink
Old 06-11-2005, 11:20 PM
phule_16 phule_16 is offline
phule_16 is starting off with a positive reputation.
Want small?
Try a Cummins BT-4 same thing as a 5.9 like in a Dodge but less 2 cylinders, turboed and intercooled I belive was 140 hp. If you are looking for a donor car look for one of those bread/potato chip delivery vans, I have one that came on a 1 ton Chevy chassis with that motor in it.....
Old 06-11-2005, 11:29 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Andy Eppink
First of all.
Welcome to FTE.
Check out our Guidelines:
http://www.ford-trucks.com/guidelines.html
And the Read First: notices at the top of each forum, it will help you understand and navigate FTE easier.
We recieved a 4.2l Turbo charged intercooled, I6 Diesel in our F-250's up until the end of 2002, in addition to the 7.3l we still recieve in Australia.
It was mated to the 5 speed ZF.
Ours was just a conventional diesel with no electronics:
http://www.mwm.com.br/site/ing/produtos.asp?idp=14
Electronic versions:
http://www.mwm.com.br/site/ing/produtos.asp?idp=15
These were also sold domestically in the Brazilian market in LHD.
If you searched around, you could probably find a slighlty used Brazilian example, and ship it to the US.
The engine was even more reliable than the 7.3l, and got around 22mpg cruising @ 65mph.
See you around...
BigF350
Old 06-18-2005, 05:50 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
You can find the calculations in a book called: Fluid Power Data Book by womack educational publications. You may be able to get a free? (Maybe a buck or two at most) copy at any fluid power equipment company or:
http://www.advancedfluidsystems.com/resources.html
or
http://www.womack-machine.com/
Looking for help on purchase flane351c 1999 to 2016 Super Duty 3 06-20-2011 02:16 PM
Fuel mileage....without the sugar coating. cleatus12r General Diesel Discussion 28 01-23-2009 09:19 PM
Powerstroke conversion advantages and power potential nicebenz68 1994.5 - 1997 7.3L Power Stroke Diesel 9 08-17-2008 09:15 PM
Emtabmm-Question on Reflash ultraclassic 6.0L Power Stroke Diesel 48 01-23-2004 10:00 AM
Considering 7.3 on new SD F-250, How's the Mileage? Andy T 1999 to 2016 Super Duty 14 07-26-1999 07:48 AM
Tags
2005, andy, engine, eppink, f250, install
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
