When changing brake pads do I need to.....
Okay fellas, I changed my brake pads on my 04 FX4 SC to some ceramic pads. My truck only has 7,000 miles on it and the rotors look like they are in really good shape, normal wear! I just changed the pads all the way around without turning the rotors. Someone told me that I should have turned the rotors regardless when putting on new brake pads. Is this correct? I didn't see any need to waste the money when they just had the normal wear, no major groves. What do you folks think? Thanks!
4x4twinkie I bought them from tirerack.com. I got the Akebono ProACT Ceramic Pads and they set me back about $140 to include shipping. That is for front and rear pads...
So far I am very happy with them. I only have about 100 miles on them but so far not a hint of breakdust and considering the fact that I didn't resurface my rotors there is no noises coming from the brakes. As I put more miles on them I will post again. I'm hoping that they remain noise free! As far as braking power, I have noticed a difference between the new pads and the stock. The new pads are much better. Personally I think it was worth the money....
In the world of those who routinely perform brake jobs, one will find that the rotors are routinely turned to 1.) eliminate the possibility of pedal pulsations/vibrations and 2.) remove any glazing on the rotor for better seating of the new pads without squeaks.
That said, I do not turn the rotors unless they are out of round or have been grooved. I do routinely take a small sander with some 80 - 100 grit and break the glaze on the rotor surfaces. This does seem to have a positive effect on the pads seating without squeaks.
For whatever it is worth.
Russ
Russ
