1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
98 Expedition how to remove front rotors
Old 06-11-2005, 01:35 PM
darizonah's Avatar
darizonah
darizonah is offline
Hey all - I have a 1998 expedition, 4wd 5.8l , having one hell of a time removing the front rotors. After I remove the caliper is the rotor attached in anyway to the frame?. Just not sure before I start beating on the rotor?
Thanks
Dave
Old 06-11-2005, 03:22 PM
saltzy's Avatar
saltzy
saltzy is offline
Oh, they're attached by forces heretofore unknown by man. Do a search on this forum and you will see various ways--from the creative to the extreme--of getting them off.
Best of luck.
Old 06-12-2005, 08:53 AM
prcrboy's Avatar
prcrboy
prcrboy is offline
After removing the caliper bracket too, they are held on by years of rust and brake dust. If you plan on replacing them, just hit the back side of them VERY hard and after a couple of blows they should come off.
Old 06-14-2005, 10:39 AM
fellro86's Avatar
fellro86
fellro86 is offline
I just did this to my brother in law's Expy, what a headache! I have never had a set of rotors stick so bad! I heated the rotor around the hub with the torch, still didn't give, so I heated some more and contined to wail on them, finally the left side rotor cracked and it came off. Well, the right side wasn't going to give at all, so i finally just cut the rotor a bit, such that it would crack, and wailed on it, came right off! Never had to do that before...
Oh, and becareful burning the rotor, don't let the flame go behind it to the topside of the spindle... the ABS sensor gets a little warm....
Old 06-14-2005, 03:25 PM
luxury's Avatar
luxury
luxury is offline
Old 06-14-2005, 04:32 PM
fellro86's Avatar
fellro86
fellro86 is offline
that makes sense... have to remember that.
Old 06-14-2005, 08:10 PM
darizonah's Avatar
darizonah
Thanks guys, I could not get them off using the trick. Took it to just brakes, did a good job for about $100 more than parts would have cost me.
Dave
Old 06-15-2005, 01:43 AM
jester34's Avatar
jester34
jester34 is offline
The easy way to do it is get a 5lbs short handle sledge hammer and beat the hell out of it until it comes off or comes to peices. It worked for me!!!!!!!
Old 01-28-2006, 08:46 PM
perardua's Avatar
perardua
perardua is offline
Rotor Removal
I purchased a 1998 Ford Expedition that sat in the auction yard for a year before I acquired it. Redid alot of front end work and brake work (I do this to any used vehicle I purchase) I tried a 20 lb maul to remove rotors, did not work. I ended up cutting out a large piece of the rotor with a grinder and using a large pry bar to crack the rotor and they both came off!!
Old 01-29-2006, 01:30 AM
ZUGtastic!!!'s Avatar
ZUGtastic!!!
ZUGtastic!!! is offline
1 can of pb blaster, 1 hour of wait time, a small sledge hammer
Old 02-01-2006, 12:48 AM
austinjorg's Avatar
austinjorg
austinjorg is offline
Talking Rotor Removal trick
Originally Posted by luxury
2003/EB/2WD/5.4 30.000mi.
Someone should come up with a catchy name for this trick. Definite lifesaver.
Whoever 1st thought of it should have got the "Nobel Peace Prize".
Jorg
Todd Fuller
12-31-2016 08:53 PM
FSU2Times
52
08-08-2012 01:29 PM
TennesseeMustangPerf
1999 to 2016 Super Duty
12-17-2010 01:18 PM
antoine
02-28-2006 08:45 AM
Kenwood
04-20-2005 11:20 AM
Quick Reply: 98 Expedition how to remove front rotors
