98 Expedition how to remove front rotors - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-11-2005, 02:35 PM
darizonah darizonah is offline
darizonah is starting off with a positive reputation.
Hey all - I have a 1998 expedition, 4wd 5.8l , having one hell of a time removing the front rotors. After I remove the caliper is the rotor attached in anyway to the frame?. Just not sure before I start beating on the rotor?
Thanks
Dave
Old 06-11-2005, 04:22 PM
saltzy saltzy is offline
saltzy is starting off with a positive reputation.
Oh, they're attached by forces heretofore unknown by man. Do a search on this forum and you will see various ways--from the creative to the extreme--of getting them off.
Best of luck.
Old 06-12-2005, 09:53 AM
prcrboy's Avatar
prcrboy prcrboy is offline
prcrboy is starting off with a positive reputation.
After removing the caliper bracket too, they are held on by years of rust and brake dust. If you plan on replacing them, just hit the back side of them VERY hard and after a couple of blows they should come off.
Old 06-14-2005, 11:39 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I just did this to my brother in law's Expy, what a headache! I have never had a set of rotors stick so bad! I heated the rotor around the hub with the torch, still didn't give, so I heated some more and contined to wail on them, finally the left side rotor cracked and it came off. Well, the right side wasn't going to give at all, so i finally just cut the rotor a bit, such that it would crack, and wailed on it, came right off! Never had to do that before...
Oh, and becareful burning the rotor, don't let the flame go behind it to the topside of the spindle... the ABS sensor gets a little warm....
Old 06-14-2005, 04:25 PM
luxury luxury is offline
luxury is starting off with a positive reputation.
Old 06-14-2005, 05:32 PM
fellro86's Avatar
that makes sense... have to remember that.
Old 06-14-2005, 09:10 PM
Thanks guys, I could not get them off using the trick. Took it to just brakes, did a good job for about $100 more than parts would have cost me.
Dave
Old 06-15-2005, 02:43 AM
jester34 jester34 is offline
jester34 is starting off with a positive reputation.
The easy way to do it is get a 5lbs short handle sledge hammer and beat the hell out of it until it comes off or comes to peices. It worked for me!!!!!!!
Old 01-28-2006, 09:46 PM
perardua perardua is offline
perardua is starting off with a positive reputation.
Rotor Removal
I purchased a 1998 Ford Expedition that sat in the auction yard for a year before I acquired it. Redid alot of front end work and brake work (I do this to any used vehicle I purchase) I tried a 20 lb maul to remove rotors, did not work. I ended up cutting out a large piece of the rotor with a grinder and using a large pry bar to crack the rotor and they both came off!!
Old 01-29-2006, 02:30 AM
ZUGtastic!!! ZUGtastic!!! is offline
ZUGtastic!!! is starting off with a positive reputation.
1 can of pb blaster, 1 hour of wait time, a small sledge hammer
Old 02-01-2006, 01:48 AM
austinjorg austinjorg is offline
austinjorg is starting off with a positive reputation.
Talking Rotor Removal trick
Quote:
Originally Posted by luxury
2003/EB/2WD/5.4 30.000mi.
Someone should come up with a catchy name for this trick. Definite lifesaver.
Whoever 1st thought of it should have got the "Nobel Peace Prize".
Jorg
Front Brake Disc Rotors, Finding a Cure? Todd Fuller 1997-2006 Expedition & Navigator 5 12-31-2016 09:53 PM
04 f250 front brake rotor removal AlSwope 1999 to 2016 Super Duty 5 11-08-2016 11:38 AM
Front Rotor removal EXbowtieguy 1999 to 2016 Super Duty 17 11-08-2016 11:17 AM
how to remove rotors antoine Explorer, Sport Trac, Mountaineer & Aviator 3 02-28-2006 09:45 AM
Rear disc wear Geoffmary 1997-2006 Expedition & Navigator 2 01-08-2006 04:12 AM
Tags
1997, 2005, 2wd, 98, change, expedition, ford, fprd, front, removal, remove, removing, rotars, roters, rotor, rotors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
