Help, no windows,radio, gauges,dome light? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-11-2005, 01:51 AM
DaveDudek DaveDudek is offline
DaveDudek is starting off with a positive reputation.
Red face Help, no windows,radio, gauges,dome light?
Hello all, I`m new here and just bought my first 2002 7.3L Ford truck a few months back. Everything was working fine and I woke up the next morning and I noticed my dome light, dash board (gauges and warning lights), radio, & power windows were all not working?? The truck starts up just fine and runs good. I checked the fuses down below the steering wheel and they are all fine??
Please does anybody know where I may be able to look?
Old 06-11-2005, 01:54 AM
empiretc's Avatar
empiretc empiretc is offline
empiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to all
did you check the fuses under the hood?
Old 06-11-2005, 02:02 AM
I can`t find any under the hood? I thought there may be some located on the drivers side fender well, am I looking in the wrong place? Thanks.
Old 06-11-2005, 02:05 AM
empiretc's Avatar
they should be on that side. look in the manual if you have it. it gives you a break down of each fuser, relay, etc..
Old 06-12-2005, 01:20 AM
locash locash is offline
locash is starting off with a positive reputation.
I had the SAME EXACT PROBLEM on my 2002 F350.. Turns out, my passenger side dome light bulb burnt out, causing the fuse to blow in the underdash fuse box. It took me awhile to find the problem, but when I replaced the fuse, it blew again. After finally removing the blown bulb, all was perfect.. I still havent replaced that stupid bulb.. Hope this helps you, I was frustrated for a bit..
Old 06-12-2005, 08:40 AM
Quote:
Thanks! After I get out of work today, I`ll check that out.. I`m gonna cross my fingers.
Old 06-12-2005, 11:16 PM
Thumbs up
ALRIGHT!! THANKS!! It`s fixed, I moved the wire on the rear dome light and now everything is working. There must be a sharp corner cutting into the wire and grounding it out someplace?? I went through a half dozen fuses and it took about 1/2 hour, THANKS!
It`s weird that one fuse controls sooo much??
Old 06-12-2005, 11:49 PM
Flinno18 Flinno18 is offline
Flinno18 is starting off with a positive reputation.
Yeah I found that out the hard way when I pulled it for the ignition chimer( keep the dome light from coming on). It also shuts off the brake release for the shifter on automatics as well!
Old 06-12-2005, 11:55 PM
Orezona's Avatar
Orezona Orezona is offline
Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.
Which number is this fuse? Sounds like I need to carry an extra.
DaveDudek, glad to see you were able to get it figured out. Stuff like that can drive a guy nuts.
Old 06-13-2005, 12:09 PM
It's fuse #15 under the dash. Just a little bitty 5 Amp can cause all those problems!
Old 06-13-2005, 05:08 PM
Orezona's Avatar
Wow, thanks for the heads up and info.
Old 06-13-2005, 06:47 PM
ReserectedSD's Avatar
ReserectedSD ReserectedSD is offline
ReserectedSD is starting off with a positive reputation.
LOL, glad to hear you found out the easy way. I had the same problem with mine when it was up and running. Mine ended up the ground on the drivers side kick plate wasn't connecting good enough. We went thought all the fuses a few times and were getting very upset and just started searching for grounds...
ultrahog carpenter01 1999 - 2003 7.3L Power Stroke Diesel 0 12-18-2015 11:04 AM
Intermittent radio, flashing dome light, etc. bekko 1999 to 2016 Super Duty 5 11-01-2013 03:22 AM
Installed LED dome lights, windows and radio will not work now lakewood 1999 to 2016 Super Duty 6 03-07-2013 06:40 PM
Help Me Please!! Electrical Issue has my head spinning miserableloser 1999 to 2016 Super Duty 7 10-21-2012 12:25 PM
Electrical Problem (fuses and relays good) Reidicus 1999 to 2016 Super Duty 24 02-04-2012 11:04 AM
Tags
2002, 2005, dome, f350, ford, gauges, light, power, radio, windows, windowsdome
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
