Ford Window Shields (F150 05 SuperCrew)
haven't put these on yet.. but......
i kinda mocked them up before actually sticking them and it doesn't look like they are going to line up correctly.....
it seem as though you have to jam the left front of the front door sheild underneath the side mirror plastics (mounts) in order to get them aligh them correctly on top of the door trim... and once you jam them in there the side mirror plastics stick out a little.. very unprofessional..... especially with it being a Ford Accessory....
the rear door window sheilds don't even line up with the door trip... they are too long... if you place them over the rear door trim, going back to front, (note, plastic trim, not actual metal door)... it hangs off the other end and collides with the windows shields for the front door.......ugh....
i would have expected a better overall fit from Ford....
actually, i saw these installed on another F150... i guess i was mocking it up wrong.....
the front ones go on top of the side mirror plastics, not under...... it fits much better but still looks kinda funny as the edges of the shield are square and not beveled down to fit flush...
but it works.... and looks good .... black on black....
Archion
06-14-2016 08:02 PM
jsandlin
12-30-2008 09:08 PM
