A/C short Cycles
A/C short Cycles
My question is it normal for the A/C compressor to cycle several times a minute? The A/C is cooling very well and cools the cab even in very hot weather. It was over 90 today and humid.It doesn't seem to cycle as much in mild weather.
I took it in for the dealer to check everything today,and was told everything was fine,including the charge,ect.ect. The service manager took it for a ride and felt it was running normal. This is my first F150,however I have leased 3 Expeditions and never noticed the short cycling with them. The truck is a month old so if they missed something it gives me three years to see if it's going to stay working. I would like some feedback from others to help me know what to do, or not to worry. Thanks in Advance!
Fred
2005 F150 Lariat 4 x 4
Fred
I hope it's normal.
https://www.ford-trucks.com/forums/s...d.php?t=248434
My beauty has been cycling every 7-8 seconds from day one. I've had the AC system checked out and the dealer didn't find anything blatantly wrong. They report that vent temp is ok and manifold pressures are within speck.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Biggziff, mine doesn't short cycle in the driveway either,mostly going down the highway and only after it's been on for 5 to 10 minutes. I don't remember it doing it as much in cooler temps either. The hot weather seems to increase the cycles to every 8 seconds. If I can't find a cure, I will do the same thing I do on my other Ford's when there's a noise problem, and that's turn up the radio!
Fred
Fred
