How do I remove my radio - 2005 F350? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-09-2005, 03:35 PM
Pau Hana Pau Hana is offline
Pau Hana is starting off with a positive reputation.
I've looked all over for instructions on how to remove the radio in my '05 F350 but haven't had any luck. The radio does NOT have the 4 holes in the front, so the little "U" tools won't work. I'd like to pull it out to see if the dash hole will accept a Kenwood AVIC-D1, but haven't figured out how to get the darned thing out and don't want to damage the dash blundering around on it. Can anyone enlighten me? THANKS!!!
Old 06-09-2005, 09:12 PM
Jawbreaker Jawbreaker is offline
Jawbreaker is starting off with a positive reputation.
The entire Benzel comes off to reveal 4 bolts holding the radio in. Move the gearshift lever to its lowest point and grap the benzel from both sides and pull. There are some wires you may need to release. When I put a Xm fm modulator direct input,I was able to do it without removing it completely. Do a search of this forum and somebody has posted a detail removal step by step. You may need to do that to put in a new radio.
Old 06-09-2005, 09:30 PM
towandcamp towandcamp is offline
towandcamp is starting off with a positive reputation.
you can also just go to crutchfield and buy step-by-step instructions for installing radios. they are specific to model years.
Old 06-09-2005, 10:40 PM
jetact's Avatar
jetact jetact is offline
jetact is starting off with a positive reputation.
Here is a step by step with some pictures to help.
http://www.richgann.com/radioremoval.pdf
Old 06-10-2005, 08:43 AM
Thanks for the information! The pictures are just what the Doctor ordered, and I appreciate you guys being so quick to reply.
Old 06-10-2005, 12:32 PM
Kraut Kraut is offline
Kraut is starting off with a positive reputation.
jetact.....
NICE LOOKING screen install.....
I love it.... would love to put a similiar set up with a nav system.
Old 09-12-2005, 07:29 PM
gagnonconsulting's Avatar
gagnonconsulting gagnonconsulting is offline
gagnonconsulting is starting off with a positive reputation.
Thanks for the great pics of the dash removal. I am trying to hook my MP3, which is part of the Lowrance Nav iWay500, into the Aux input of the factory stereo. Sounds as though this might not be feasible, connector wise, through. Has anyone got any info on this yet?
Rich
2006 F-350 Lariat
Old 09-13-2005, 08:15 AM
Bagger Bagger is offline
Bagger is starting off with a positive reputation.
great write up! Thanks
RADIO REMOVAL '51 F1 v860rich 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-03-2016 12:02 AM
Removal of factory radio 1992 F150 phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 5 12-17-2013 05:16 PM
2008 escape radio display has quit durbin Escape & Escape Hybrid 5 03-31-2012 11:31 AM
Best way to run electical wires through dash 2006 F350 tap1946 1999 to 2016 Super Duty 13 04-20-2011 07:31 AM
Installing a Newer OEM radio in my truck timsvtgen1 1997 - 2003 F150 0 03-18-2008 06:36 PM
Tags
05, 2005, dash, f350, ford, pull, radio, remove, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
