thrust bearings
06-09-2005, 12:03 PM
on
thrust bearings
I was just reading and found out that the thrust bearings for the FE motors are different. 58-63 are different from a 64.
does anyone know about this and how much different?
if so and i have the wrong ones can i buy just a thrust bearing?
06-09-2005, 12:09 PM
In '64 they went to a wider thrust bearing. Early ones can be used in a later block, but later ones cannot be used in an earlier block.
06-09-2005, 01:31 PM
on
damn damn damn damn that is not cool i am worried now
does anyone know the sizes? ID and OD
06-09-2005, 01:55 PM
What year is your block?
Pre-'64 engines use a .465" flange thrust bearing. Later engines use a .535" thrust bearing.
06-09-2005, 07:02 PM
Pre 64 thrust bearing # Federal Mogul 4020M. Small set back. See if you can have one for Sat del locally. G.
06-21-2005, 03:26 PM
on
i have a 63 block
where would i need to measure to check this?
06-21-2005, 03:29 PM
on
I have put it in the block and i seem to have no prblems. that i can tell. But still what do i need to check?
06-21-2005, 03:43 PM
on
also I have a 2U crank if that helps any
06-21-2005, 03:50 PM
on
this is the kit that cam with my rebuild kit from summit
FEM-4261M10
I am thinking that they might be what i need ( i hope
06-21-2005, 04:00 PM
on
Quote:
FEM-4261M10
the FEM-4261M10 is for the ten under that i had the crank ground
06-21-2005, 05:38 PM
I don't think it would have went in if it were wrong. Do you have the old thrust bearing to compare to?
06-22-2005, 12:10 AM
on
nope i wish i did so that i could check but that got sent off to the machine shop with the crank and block
06-22-2005, 05:06 AM
The kit you have might have the old style bearing possibly. Not sure. Is it a federal mogul bearing? The old F/M I have here out of the 63 406 have: fm 2304 CP BO stamped in them. This is off the thrust bearing. I'd be certain you have the correct bearing. It does sound like it fits ok though. G.
06-22-2005, 07:04 AM
on
Quote:
yes it is a federal mogul bearing. It slipped right in with no problems. and good close fit so i am good to go
piscespokerbrat
Escape & Escape Hybrid
06-28-2015 07:37 AM
Brad_81Ford
01-13-2012 08:58 AM
richsoucie
1999 to 2016 Super Duty
03-03-2009 10:15 AM
Rico82nd
13
10-28-2003 08:01 PM
