belt whines on startup
man i suck at using the search i can never find what im lookin for... anyways i remeber reading about how to solve the problem of the fan belt whining on start up, i believe using glue or something, can anybody help cause its starting to get worse even on warm start ups it does this now, thanks for the help
sorry kbronco whats a v-belt does it do the same thing as a serpintine (thats what i have by the way) or is it something totaly diff
Kemicalburns the altenator pulley is a little bit bigger than the original so i think its tighter, but i thought the self tightening thing is supposed to fix it. i have a 90 302
My old truck had a series of V-Belts on the engine accessories, not a single or dual serpentine. The pulleys were a single deep groove and there were not tensioners on it. Check your tensioner, they wear out. Don't use belt dressing for any reason, search the subject here and you'll see why.
I had this problem also....I purchased a Goodyear "Gatorback" belt from my local Autozone instead of the Dayco brand I got last time. It was about $25 bucks as opposed to $17 for the cheaper one.....it works like a charm! It has an odd "staggered" pattern instead of the traditional "v-groove" design of a normal serpentine belt.......
