lawn mower transmissions
Amyone know anything about hydrostatinc transmissions on lawn mowers? I had a "Powr Kraft" (which I foumd out is MTD) given to me a couple of years ago and the tranny keeps getting slower and slower and making a lot of whinning noise. I was told to put automatic tansmission fluid in the fill tube but that didn't help. Any suggestions would be appreciated.
Hold on !!! look under the rear axle behind the mower see if it has a tag that say's Hydro gear ! I need the model # on that tag . not all unit's are the same. just becuse it is an hydrostatic trans. All unit's use diff. fluid's. per OEM spec's !!! WE all look a like Right !!! Wrong !!! If it don't have a tag give me the model # of the mower Most of the mower's sold were MTD's at ward's Don
I have a YardMan by MTD with hydostatic drive. It has a FORD spin on oil filter underneath and if yours does also, it may be clogged. Mine says to use 30 wt hydraulic oil and I have never found any. ATF is too thin for the seals. I have used 30 WT penziol for years and when it needs changing (or is cold outside), it starts to groan. I have also had to change out some of the hydraulic control valves and hoses over the years (25 years old) The unit has a Techumsi (sp) pump unit and 18 HP 2 cyl briggs engine. Best darn mower I ever had.
Dialtone
Dialtone
YES , From a person that work's on em for a living !!!!!20w-50 motor oil . Clean the area around the fitting that the hose goes to remove the fitting fill it to 1" to 1 & a half " from the top of trans. Run it for a few mins. fwd. & rev. recheck it ! to the same level ! There is a filter inside the trans . but if it works leave it alone ! Ya have to know how to reseal trans. or it will leak !
Don
Don
Duback and Yomow,
How do you drain the thing? I have the same problem with my MTD yard machine (I know, junk), and was hoping to drain and refill without removing the rear end.
I don't see any sort of drain plug on this thing! What kind of cruel joke is this?
Thanks in advance for any help!
James
James
Yup, your pump is getting wore out. I used to mow a park nearby where I live with this old Bolens Husky garden tractor (I think it was made in the mid '60s). It has the pedal you had to push with your foot (I think it was called "auto-drive", it supposedly mimmicked driving a car).
Anyways, it got so bad that if there was even the SLIGHTEST uphill you would have to floor it and the trany would groan and moan and the mower would barely go up the hill. Then again, if I had to lug around a 62" Woods pull-behind mower for 50 years, Im sure Id moan and groan too! LOL
Octane
Octane
