How much freon to charge AC on Explorer??? - Ford Truck Enthusiasts Forums
Old 06-07-2005, 10:27 PM
Merlin509 Merlin509 is offline
Merlin509 is starting off with a positive reputation.
I just installed a new AC compressor in my '94 Explorer and was wondering how many 12oz cans of R134a it will take to fully charge the system. I've put in one 12oz can of oil and 4 cans of R134A. The compressor is running and blowing cold air, but there isn't much pressure in the system.
Also...Is 12oz enough oil?
Any help would be appreciated.
Thanks
Old 06-07-2005, 11:18 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
There should be a sticker up by the fan blower somewhere, that will tell you how much to charge. R134a and R12 charge amounts should be close to equivalent. I've heard they work best with 80% the recommended amount when converting to R134a. My '92 took about 3.5 cans. Typically, you want to charge 'em up to where the compressor doesn't cycle. If it blows cold and doesn't cycle on max AC with the fan turned up all the way, it's good. More pressure is not good.
12oz. is plenty of oil. Your compressor will let you know if it's not.
Old 06-08-2005, 07:09 AM
don96exp don96exp is offline
don96exp is starting off with a positive reputation.
There are two service ports on teh AC system, The high pressure or liquid side and the low pressure vapor side. Freon is added to the low pressure side and when running the low pressure will vary between 20 and 35 PSI, this is normal. If it appears that there is not much pressure and your looking at the low side while the AC is on, this is normal. When the AC is turned off and the high and low side equalize, the reading on the low side will be higher. Be carefull not to overcharge the system. Sorry for the long winded reply.
89 AC converted to a134 now how much do Akzep69 1978 - 1996 Big Bronco 2 06-20-2015 05:07 PM
Doing a complete charge of A/C Redwolfbuddy Cooling, Heating, Ventilation & A/C 37 07-31-2013 10:43 AM
How much PAG oil for a 1990 F250 A/C system CountryBumkin 1987 - 1996 F150 & Larger F-Series Trucks 3 07-06-2012 07:39 PM
New compressor and dryer Tim Young Cooling, Heating, Ventilation & A/C 5 09-09-2006 02:18 AM
R-134a Conversion Rob88 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-28-2000 12:15 PM
Tags
2002, 2003, 2010, 95, air, condotioning, explorer, ford, forum, freon, frion, hold, refrigant, refrigerant, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
