coolant mix ratio question
any info appreciated... just did hoses, belts and coolant on 99 PS 7.3 question about coolant... capacity stated in owners manual says 32 qts. thats 8 gallons by arizona math. I flushed drained and replaced 4 gallons of new green coolant expecting to have to add an additional 4 gallons of water to get the 50-50 mix. the resevior was full and only went down a little with a good warm up. Is there enough water in the water jacket and undrainable areas of the block to hold 4 gallons of water. Napa says 32 qts = 8 gallons 1/2 that is water 1/2 that is coolant no problem. they're the only ones that are certain... Ford dealer says "that seems like a lot, we only add about 2 or 3 gallons with every flush". doesnt lend itself to a feeling of confidence. also truck doenst seem to over heat - added two bottles of anti-cavitation fluid to coolant as per ford dealer advice. the instructions state 4 oz per gallon so the math works out in my favor. any experience out there?
thanx
thanx
the additive used to be part # "FW-15" now its something else. But it is definitly reccomended every 6 months that you refresh the coolant with additive to prevent cavitation around the water jacket as it will eat through the sleeves, this is per ford dealer and the conventional wisdom of a mechanic friend of mine....NAPA does carry a version of it but I was told the ford brand is actually the best and about $ 1.oo cheaper per bottle.
The additive is now called VC-8. Even though the specs say it takes 8 gallons you really cant get in more than 7 total including the added VC8.
More than likely you will need to add a total of 3 pints of the VC8 to get your cavitation protection where you want it after testing. I just did this within the past month so all of this info is still fresh on the mind
Originally Posted by empiretc
Ive always been told it is a better idea to run pure antifreeze. Especially where I live. This time of year we have been seeing 105 pretty often. I know water cools better than anti, but anti does evaporate. Any input on the theory?
I see what you mean KWIK. My old man has run pure antifreeze in all of his farm equipment ever since he moved down to blistering heat of south texas. We know several people who have blown engines by doing the other extreme- running pure water.
I know I have never truly run pure in my autos cuz there is always some in the block that you can never really get out. When I replaced a thermostat in my stang, i replaced the amount that was lost with pure.
Its getting harder to do though cuz many auto parts stores only carry premixed antifreeze these days.
If you all want to take it a step further, consider Evans coolant. Non water-based coolant. Lot's of money to do so, but you'll never boil over.
Or a less expensive alternative is Redline Water Wetter. Racers use it with just water, but they usually drain the system after the race. There's more information on thier website.
CountryMonkey07
03-27-2015 09:52 PM
99ExpyProblems
1999 to 2016 Super Duty
11-09-2013 06:53 PM
99ExpyProblems
11-08-2013 07:26 PM
