vibrates at 55 mph
vibrates at 55 mph
I have a 98 f150 v6 stick ,and it vibrates starting at about 55 mph, but only when I give it gas. I quess it started a couple days after I put chevron fuel injector cleaner in. Oh i have 122,000 miles. I have not taken it anywhere yet yet I really hope its easy. Can someone give me some goodnews please.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
I have a 97 f-150 ext. cab 4x4 and had the same problem. Mine was a little bit more major, my transsmission to transfercase bolts were loose and causeing a bad vibration only when on the gas. I don't know if yours is four wheel drive but you mmight want to make sure everything is tight. Hope it helps you!
Pioneer Ford
1978 - 1996 Big Bronco
35
12-27-2002 09:13 AM
