1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
transmission gear orange indicator is shifted?
Old 06-05-2005, 04:06 PM
boffah's Avatar
boffah
boffah is offline
indicator is shifted off to the right one...
here are some pics for those of you who ever have the same prob..
Old 06-05-2005, 05:27 PM
boffah's Avatar
boffah
boffah is offline
I think the white piece is broke at the top... is this the common failure of the shift indicator prob.
Does anyone know the replacement part number?
Thanks
Old 06-05-2005, 07:55 PM
Luzer27's Avatar
Luzer27
Luzer27 is offline
Very common take it apart and shim it with some washers on the back side, so it does not rely on the broken piece. You really don't need to be able to ever adjust this once you get it set. Good luck I can take a picture if you need it for assistance.
Dave
Old 06-05-2005, 09:27 PM
boffah's Avatar
boffah
boffah is offline
could you take a picture? I'd appreciate it.
Thanks Dave!!
Old 06-06-2005, 01:17 AM
Luzer27's Avatar
Luzer27
Luzer27 is offline
I will get it as soon as the sun shows it head or by noon which ever comes later. LOL
-Dave
Old 06-06-2005, 01:30 PM
Luzer27's Avatar
Luzer27
Luzer27 is offline
Hey I added a gallery with 2 pictures of my fix. All I used was two small nuts on the opposite side of where the thumb wheel used to be. I also removed the rest of the broken tab. Hope this helps.
Dave
Old 06-13-2005, 09:29 PM
boffah's Avatar
boffah
boffah is offline
THank you!!!
Old 12-10-2005, 03:20 PM
quick35th's Avatar
quick35th
quick35th is offline
The part number for the fix is XL3Z-7A110-AA, and it cost $20 from Ford.
Shane
Old 12-12-2005, 11:53 AM
quick35th's Avatar
quick35th
Guys make sure that both white plastic arms are there before you leave Ford with the new part. Ford seemed to have sold me an already broken one and I did not realize it until I had in in my expy already. I ended up rigging it up with a crap load if gasket sealer so that it keeps tension. Seems to be holding good so far.
Shane
Raleigh1
1978 - 1996 Big Bronco
682
03-18-2016 01:29 PM
Milpool
03-06-2016 03:31 PM
KA7JUN
New Member Introductions
09-28-2015 07:03 PM
DaXman
07-03-2015 05:38 PM
Jasonpremo
11-20-2013 07:19 PM
Quick Reply: transmission gear orange indicator is shifted?
