You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey, On my truck I have a drop in liner, and on the out most coners i have loop things that i use to tie stuff down, and they hold the liner in place. my current issue is that when it gets hot outside. the liner expands and ripples up in the middle. What can i do to anchor the sides of the liner down( it comes up on top of the bed rail) besides adding more loop anchors.
__________________
1986 F250 4x4 NP 4speed.
302
2 1/4 inch exhaust gutted cats
sony f5000 headunit, alpine door speakers. amp and sub next.
It's pretty strong stuff, just make sure it's the automotive grade used to stick on mouldings and stuff like that. You could screw some diamond plate or something similar on top of the rails too. The liner is probably flexing cause its too tight, maybe you can enlage the holes around the anchors?
the holes are about 1 inch diameter, and the anchor's bolt is about 1/4 inch. When it was fully hot I loosend the anchors and tried to flatten the bumps and then tighten down the anchors again. Now when its cooler like at night, the ripples are practcly non existant, but when hot they are somewhat surpressed.. I'll check with a auto parts place for the 3m stuff and I'll put some weights on the ripples to keep it down... then worst comes to worse ill put some screws in haha.
__________________
302
