Rear axle out of alignment - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-05-2005, 02:34 PM
Super Steve Super Steve is offline
Super Steve is starting off with a positive reputation.
I took my truck to big-o to get the wheels rotated and balanced and they recommended an alignment. They found that that one rear wheel is actually 1/2 an inch forward of the other. Apparently the superlift springs are off. This explains why my truck pulls to the right. Has anyone else run into this problem with aftermarket springs?
steve
Old 06-05-2005, 03:41 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
How do they know its the rear? Did they measure from the axle tube to a shackle bolt?
Reason being is that I've seen rear axles being off and it will steer fine. With that said the only way you get for and aft problems is either the locator pin bolt etc is not in the hole or you got bad springs or wrong application. You have to find the exact problem and examine carefully.
Dick
Old 06-05-2005, 04:10 PM
jetjock16 jetjock16 is offline
jetjock16 is starting off with a positive reputation.
as the spring compresses you axle moves back.. so if one spring even sags a little more then the other, the rear axle could be slightly out of alignment.. measure from the Bolt at the front of the spring that bolts it to the frame, to on of the top bolts on the backside of the wheel.. the threads that stick out to hold the hub assembly on, you'll see if you look, you want a specific point as just measuring to the axle tub is not accurate enough. This problem has been posted before, if there withing 1/4" of each other, it is as straight as on stock trucks.. if it has been like that for any lenght of time you would notice tire wear
Old 06-06-2005, 12:48 AM
They put it on one of those electronic alignment racks. A sensor thingy mounts to the face of each rim and the computer shows the angles and positions of each rim.
I haven't measured yet to see if the axle locator bolts are different from side to side, but I imagine that is most likely what it is.
steve
Old 07-10-2005, 08:49 PM
JaBerryhill JaBerryhill is offline
JaBerryhill is starting off with a positive reputation.
Did you ever find out what your problem is? I have the same prob. My truck doesnt track down the road straight and didnt happen until i put lift on but i only used blocks in back so im pretty confused on mine as well. On the driver side rear the spring pack isnt lined up with the bottom helper spring but the pass side is lined up fine. When your driving behind my truck you can see the front left tire sticking out. Looks really weird and drives me nuts.
Old 07-10-2005, 09:00 PM
Quote:
All ford trucks have a wider stance in front then rear, and if you look closely when following, will look like there out of allignment or whatever... it is just becuase the front tires stick out about 1/2" more then the rears
Old 07-10-2005, 10:45 PM
marv02's Avatar
marv02 marv02 is offline
marv02 is starting off with a positive reputation.
Is you track bar have a preload on it if so you'r front axle mite be not centered cause the pulling, Are you'r tires worn this will cause pulling air pressure will cause pulling, try swapping you front tires side to side and see if the pull still there it could be a bad tire.
How you tires wearing look like is it feathering spots that where it's been Cupping is wearing flat completly across the foot print Ect this will tell you about you'r truck.
Big O-Tires most of the time won't tell you some of these kids that do the work don't know what to look for..
If you truck is crabing if the rear end is that far out of line the tire will wear funny also just like a front end is out of wack.
Old 07-11-2005, 03:48 PM
Yeah its weird. Never had a problem with tire wear but i did keep them rotated every other oil change. I just went with brand newe 36 iroks still has the pulling. Ive had my adjustable trac bar cut and sleeved inth emiddle to shorten. Spent alot of money with diff shops around town and everyone says they can fix it but then its never fixed. So My next step was to buy a whole new lift and start over and pray.
Old 07-11-2005, 06:20 PM
Right now I'm stuck in New Mexico until February, but as soon as I get back home (where I have all my tools ) I'm going to take measurements to verify what the guys at big O told me. And if it is off like they said, I'll make a lift block that has offset locator pins so as to move the rear axle the way it needs to go.
Broken leaf spring source of bad alignment TheRooster 1999 to 2016 Super Duty 7 08-07-2016 04:38 PM
...alignment shop? Steve Hinson Tennessee Chapter 6 06-14-2016 05:57 PM
F150 Leaf Spring replacement sammer4u 2004 - 2008 F150 12 12-19-2014 08:21 AM
Proper Door Alignment Method NBC-Steve 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-25-2012 10:18 PM
Rear Wheel Alignment - Dually ?? UaVaj 1999 to 2016 Super Duty 10 04-06-2010 06:57 PM
Tags
alignment, axle, ford, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
