Need opinions - Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
Need opinions
Old 06-05-2005, 12:46 PM
CBSuperduty's Avatar
CBSuperduty CBSuperduty is offline
CBSuperduty is starting off with a positive reputation.
Need opinions
OK. Long time since I have posted here but here we go. I have always wanted to build a pull truck. I have been looking lately and can't find a cheep rolling chassis so I am considering other options. I found an 89 F250 2wd (no motor) for $500.00 (or possibly less) and the body looks to be good. I am considering this but would like your guys opinions. Any thoughts of this truck? I will need to find a cheap motor that I can build later and possibly a heavier rearend (alot of the guys use 2 ton rears). If you would like to see more specific rules CLICK HERE to see the org that I would probably pull with. It would be the 2wd Street Stock. I am not looking to have this done any time soon. Just working toward the goal. I am torn between this and just buying more toys for my diesel..... Any thoughts or ideas???
Old 06-05-2005, 09:33 PM
farmb0y's Avatar
farmb0y farmb0y is offline
farmb0y has a great reputation on FTE.farmb0y has a great reputation on FTE.farmb0y has a great reputation on FTE.farmb0y has a great reputation on FTE.
Just get more mods for your diesel, then use it to pull. Problem solved.
Old 06-06-2005, 02:25 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
problem is, the diesels don't get to pull every track, and have to work harder to get anywhere in competition...but it sure would be fun!
Old 06-06-2005, 05:31 PM
If I juice up the diesel then it would just be for fun (no truck pulling). I am still trying to decide. Any other suggestions or ideas? I will let you all know what I decide.
Old 06-06-2005, 07:51 PM
nogo73's Avatar
nogo73 nogo73 is offline
nogo73 is starting off with a positive reputation.
unless you can afford two projects I'd stick with just having the diesel never know when somthing will give and make your life a pain.
Old 06-07-2005, 04:52 PM
fellro86's Avatar
although it is fun to play around like that, it does take a bit of money and time, and never fails, something will break and cost you more money yet... as far as resale, too, forget it, you'll never recoup what you invest, the only return you can count on is the enjoyment of building it then running it... Right Rob? Occasionally there is the winnings...
Old 06-07-2005, 06:59 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
believe me my winnings haven't even come close to paying for the engine I just built, but it sure a lot of fun.
Old 06-07-2005, 07:49 PM
fellro86's Avatar
didn't figure you got very good returns, the purses can't be that good, that's why I say it has to be done for fun, as soon as you expect to make money with it, the fun is lost...besides, it isn't a very good expectation to win that regular.
Old 06-08-2005, 04:20 PM
Thanks guys. I have decided to hold off on the evilbay truck but I am going to pickup Kelley's 79 F250 (purchasing for the motor and tranny but if the frame or cab will work then great). Then I will try to start tearing into the motor and learning more about them. In the mean time my exhaust, gauges, and probably a chip for the smoker should be in sometime in the next couple weeks!
Injector questions. Jknapp79 1999 - 2003 7.3L Power Stroke Diesel 2 04-25-2012 02:51 AM
Thoughts about how to build my motor and other questions.(keywork Tractor like torque) 59flatbedford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 02-14-2012 09:08 AM
460 build rjvaughan Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 10-14-2007 11:59 PM
Pulling the big block out of storage Arnold Kenyon 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-15-2006 10:27 AM
Guys, Please Help Me With a 410 Build. lakecityg FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 42 03-12-2006 07:21 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
