VHT by manufacture is what I use that's available in any good parts store.
Called Wrinkle Plus coating, SP-201 Black. I believe you can get it in different colors. On finned valve covers like old Cal Customs, sand the fins with 180 grit wrapped around a sanding block or wood. Paint, let set up not dry then with a rag soaked in lacquar thinner wipe the fins lightly. You'll have black covers with aluminum fin tops exposed, looks great. Just a suggestion.
.....=o&o>.....
__________________
.....=o&o>.....
