Gearing
Old 06-03-2005, 08:48 PM
rsjohns2's Avatar
rsjohns2
rsjohns2 is offline
Gearing
For those of you that have changed the gearing, what is the lowest gear the stock carrier will allow? I am interested in adding 4.56 both front and rear.
Thanks
Old 06-03-2005, 11:39 PM
64f10's Avatar
64f10
64f10 is offline
4.88 if I remember when I was looking at them ... due to rev 8.8 front diff ... that is based on what I found available ... not what could potentially fit! ... I think the normal 8.8 went way up to the 6.? something!
My Gear Chart
Old 06-05-2005, 03:45 PM
rsjohns2's Avatar
rsjohns2
rsjohns2 is offline
Thanks 64F10, did you install new gearing in your truck and if so what gear was it? I am looking for better pulling power and I think the 4.56 is what I am after. I know the tuner would be better for the money but I'm not just ready to mess with that yet.
Thanks
Old 06-05-2005, 08:04 PM
64f10's Avatar
64f10
64f10 is offline
I did not put my own gears in ... had a local shop do it! You'll need some sort of tune with 4.56 gears ... unless you've 35" or taller tire because from what I hear Ford's PCM machine won't do it for lower gear combos! ... ya, seems crazy to me! But they could only get me to about 12% with my 33"'s. Had to get a tuner to dial things back in ...
