Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-03-2005, 02:42 AM
coplin's Avatar
coplin is starting off with a positive reputation.
Mercon and Mercon V ATF
I guess I could call Ford but thought I'd ask here.
Does Mercon V superceed Mercon? Can I put Mercon V in my C-6 that uses Mercon ATF?
__________________
Silver/Black 1988- F-150 XL Super Cab 2wd- 357 SOLD!You will be missed.
New Toy: White.2001 SD250 Crew Shortbox Lariat.7.3L Stroke. On 35's. 4 inch magnaflow. Autometer gauges etc. 30,000lb Gooseneck setup.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-03-2005, 02:46 AM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
this topic has been disscussed lots of times just do a search.but to anser the question the answer is no the mercon v is not made for that trans
  #3 (permalink)
Old 06-03-2005, 03:04 PM
coplin's Avatar
Ok thanks ya i read up on that and Mercon V is a semi synthetic it has too much Friction Modifiers and other crap that the C-6 does not require. In fact all the extra FM could cause transmission slippage.
__________________
  #4 (permalink)
Old 06-03-2005, 04:23 PM
ATC_250SX is starting off with a positive reputation.
Yout think the mercon V has alot of modifiers, you should research the new mercon SP, I have to deal with it at work in the new torque shifts, and man thats some really slick stuff. the sp will also seperate from conventinal mercon and mercon v
__________________
2000 F-350 SUPERDUTY,
7.3L, regular cab, 4R100, Tourque Shift Trans cooler,
SuperChips tuner, Tightened waste gate, Straight pipe.
1988 F-250, Super Cab, 7.3L IDI.
Ford 7.3L, 6.0L, 6.4L And CAT certified Diesel Technician.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
