Correct spark plug for a 98 4.0 SOHC? - Ford Truck Enthusiasts Forums
Old 06-02-2005, 02:48 PM
56speedster 56speedster is offline
56speedster is starting off with a positive reputation.
Greetings all,
I need to change my plugs and wires. I looked at the Motorcraft website and found four different plugs that will work, but I'm not sure which one of them to use. Here are the four choices: AGSF22FM, AGSF22FMF6, AGSF22PPM, and AGSF22PPMF6. Thanks for your help.
Rick
Old 06-04-2005, 03:21 PM
98explorerguy 98explorerguy is offline
98explorerguy is starting off with a positive reputation.
plugs for 98 explorer 4.0L SOHC
My friend, the way I went about getting plugs for my 98 4.0L SOCH was to go to auto parts stores' web sites and getting info. I ended up going to AutoZone and buying 6 plugs...they are MotorCraft double platinums...only use these plugs or you will have problems. They are about $6 a piece, and I hear they are the same cost at the dealer. For wires, I bought them at PepBoys for about $40, which is way less than the dealer charges for wires, and they work great. As far as exact stock number for plugs, I can't help you. But AutoZone should be able to pull up the right plug...they are the only ones I know of that carry MotorCraft plugs. I hope this helps.
Old 06-06-2005, 05:29 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Whatever you put in, make sure you check the gap and use anti-seize...
Old 06-06-2005, 02:48 PM
Pig Pen Jr's Avatar
Pig Pen Jr Pig Pen Jr is offline
Pig Pen Jr is starting off with a positive reputation.
I always get mine at Wally World... just use the handy dandy little computer they have hanging in the spark plug isle. Choose between the brands then just find the pack. I then check the gap on them just to make sure (All of the 4.0L OHV's, the 4.0L SOHC's, and the 5.0L V8 share the same gap. Its .054)
I've used Bosch Platinums and Double Plats, no dif except in price.
Full thread MC plug AGSF22WM folsomf250 Modular V8 (4.6L, 5.4L) 11 08-11-2013 04:35 PM
Escape-2006: Spark plugs AGSF22FCM (from Mondeo and Escape 2008) instead of AGSF32WM? Izb Escape & Escape Hybrid 2 07-24-2008 09:20 AM
Help with spark plugs Larry S Explorer, Sport Trac, Mountaineer & Aviator 23 07-20-2008 02:08 PM
AGSF vs. AWSF ssjrsw Modular V10 (6.8l) 0 01-24-2006 04:30 PM
Spark Plugs AKranger Ranger & B-Series 12 08-29-2004 05:47 PM
Tags
02, 2005, 40, 40l, 98, agsf22fm, change, explorer, ford, gap, plug, plugs, recommened, sohc, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
