Where can I get the cruise control button covers? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-01-2005, 12:53 PM
propellerhead's Avatar
propellerhead propellerhead is offline
propellerhead is gaining momentum as a positive member of FTE.
I need those soft plastic skin thing that covers the cruise control buttons. Anyone know where I can get OEM replacements or some aftermarket ones?
96 Ranger, 2WD, 3.0
Old 06-08-2005, 10:07 AM
Anyone...?
Old 06-08-2005, 10:20 AM
jfuchs jfuchs is offline
jfuchs is starting off with a positive reputation.
You cant get the covers have to replace the whole thing. Can buy for dealer for about 50 dollars. Disconect battery first to disable airbag. Two screws on on each side of stearing wheel under tabs. Unplug old buttons replace with new ones.I did not use the new wires with mine i just used the ols ones. There is two types left and right hand ground does not matter which one you buy sugest the cheepest . mine worked fine about 10 min.
Old 06-08-2005, 11:07 AM
So the old wires plugged right into the new switches? Are they standard wiring harness plugs or do I have to splice them?
Are you saying it took you 10 mins to install? Or it worked fine for 10 mins then it broke?
Old 06-08-2005, 11:12 AM
ledbetter ledbetter is offline
ledbetter is starting off with a positive reputation.
I've seen them on eBay. Most are used, but some are supposedly new stock.
Old 06-08-2005, 01:37 PM
The old wires pluged right in to the switch and it worked firn whole job took around 10 min.
Old 06-08-2005, 01:54 PM
Big Jim M Big Jim M is offline
Big Jim M is new and has a neutral reputation at this point.
Wink
I have a light out in one of my buttons.. IS the light bulb replacable? Or do I need another switch?
Big Jim
Old 06-08-2005, 04:04 PM
Dave257 Dave257 is offline
Dave257 is starting off with a positive reputation.
Big Jim M; try this thread...
http://www.ford-trucks.com/forums/sh...cruise+lights+
Dave
Old 06-08-2005, 04:54 PM
Thanks... sez to give em a whack.. does NOT say if the bulbs are replaceable. ARE THEY?
Big Jim
Old 06-08-2005, 06:14 PM
My 02 Ford manual only shows replacing the switch..
Dave
Old 06-13-2005, 03:14 PM
The shop manual for my 96 states the bulbs are not replaceable. The switch must be replaced.
Old 06-14-2005, 03:50 PM
dag's Avatar
dag dag is offline
dag is starting off with a positive reputation.
Old 06-14-2005, 05:11 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Changing Cruise Control Switch Lamp Bulb
Here is the procedure for replacing a lamp bulb in the cruise control switch, as set forth by JDraper over at the X-forum:
1. Disconnect the negative terminal on the battery and let the vehicle sit for at least 2 minutes. This will deactivate the airbag inflators.
2. Pry out the plastic plugs on the back side of the steering wheel. They are round and about 1" in diameter, one on each side.
3. Remove the bolts you find behind the plugs. These hold the airbag and the horn in place. Once they are out, the center of the steering wheel will come off. You should have enough wire in the airbag harness to just rest the assembly on the column or the bottom of the steering wheel.
4. There are 2 bolts that hold each of the cruise control assemblies in place. Remove them and the assemblies pull off. There is a wiring harness to each one that has a connector that you have to make sure is seated when you put it back together.
5. Pull the rubber cover (the buttons) off the circuit boards to access the light bulbs. The bulbs have a colored rubber cover on them that you will need to re-use. The bulbs have a plastic base that just twists out of the circuit board.
09 F350 Cruise Control Unresponsive 09F350 1999 to 2016 Super Duty 2 11-11-2016 12:12 AM
steering wheel question kupiec20 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-20-2015 04:22 AM
2005 Ford Explorer Sport Trac harpert46 Explorer, Sport Trac, Mountaineer & Aviator 1 06-01-2012 05:21 PM
Cruise Control Issues 96 F250 5 spd bruno2 1987 - 1996 F150 & Larger F-Series Trucks 10 08-29-2011 06:13 PM
Pressing Cruise button blows horn!?? vwhed1979 Aerostar 3 01-20-2006 11:24 AM
Tags
1999, 2000, button, buttons, control, covers, cruise, explorer, f350, ford, plastic, ranger, replace, switch, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
