u-joint location
Old 06-14-2005, 02:55 PM
LT99ranger's Avatar
LT99ranger
LT99ranger is offline
u-joint location
where are the u joints located and how do i check to see if they are worn? thanks
Old 06-14-2005, 04:50 PM
Old Speed's Avatar
Old Speed
Old Speed is offline
u joints are on the front part of the drive shaft and the rear part also. it looks like a +. there are 3 ways to tell if it is bad, alot of vibration at speeds 30mph+, bad tin can sounding noise, and the last you need to crawl under the truck and like shake the drive shaft at the front and back by the u joints, if it is bad you can feel the drive shaft move like it is loose.
