how often do you change your transmission fluid? - Ford Truck Enthusiasts Forums
Old 05-31-2005, 10:33 PM
BuiltToughF250's Avatar
BuiltToughF250 BuiltToughF250 is offline
BuiltToughF250 is starting off with a positive reputation.
my truck- 2003 F350 ext cab 6.0 turbo diesel, auto, 3.73 gears, leveling kit, 35" tires, 4" exhaust
the truck has almost 39,000 miles. the transmission fluid is pretty clean looking, and has always been at the right level without having to add much, if any. i do alot of towing, and mostly highway miles.
im debating if i should change the tranny fluid. ive known a ton of people who had no tranny problems until they changed the fluid / filter... 2 weeks later the tranny is fried.
so how often do you change yours ?? ever had problems afterwards? im pretty sure the manual says to change it at 30,000 miles... oops...
Old 05-31-2005, 11:05 PM
sierraben's Avatar
sierraben sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
Never- I have a T-18 4 speed manual.
Sorry, I had to throw that one in.
See what your manual says don't forget to use the correct type of ATF for your vehicle. I guess it also depends on how you drive and if/what you tow.
When I did have an A.T., changed it every couple of years and never had a problem. But that's me.
Good luck
Old 05-31-2005, 11:16 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
I'm pretty sure those who claim that the change of tranny fluid caused their tranny to go south had never changed it in the first place. So the tranny was going to fail pretty soon anyway. I changed mine at 30k, as the manual states because I'm still under warranty and want to keep it that way, just in case
Old 05-31-2005, 11:22 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Check with these guys down here.
Old 06-01-2005, 01:07 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
well being that you tow it is a must you change it at 30,000 the fluid loses its ability to protect the parts and will wear out the tranny and by not changing it you void the warranty trust me if you have a warranty on it and it goes they will pull a fluid sample and find out how old that fluid is and will ask for proof of service if you can't provide you buy the new 4,000.00 tranny
Old 06-01-2005, 01:09 AM
beeboy's Avatar
beeboy beeboy is offline
beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.
just change it, don't have it flushed. That seems to cause more problems than it fixes.
Old 06-01-2005, 07:29 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
Don't just change the fluid, you won't get as much changed. Use this method:
http://www.ford-trucks.com/article/i...nsmission.html
Old 06-01-2005, 07:37 AM
oppy's Avatar
oppy oppy is offline
oppy is starting off with a positive reputation.
If you do it at ~30k intervals, I don't think you really have to worry about getting every drop out. If it was me, I'd just drop the pan, check the filter and replace if needed, and refill.
Old 06-01-2005, 09:49 AM
02PSD4ME's Avatar
02PSD4ME 02PSD4ME is offline
02PSD4ME is starting off with a positive reputation.
I have flushed mine at ~25K intervals (3 times), have 77K on it now. I tow quite a bit so I change it more often
Old 06-01-2005, 10:07 AM
Quote:
To check the filter you need to cut it open. So checking is out, just replace it.
Changing the fluid in the pan and not changing the fluid in the converter is a waste of time and money. You will change less than half of the total this way. The article I posted above will change about 90%-95% of the fluid. It also has an option to change the filter. The author said that he changes the filter every other change.
Old 06-01-2005, 10:23 AM
oppy's Avatar
Umm - the filter is basically a screen. No need to cut it open, it's easy to see if there's gunk in it.
I guess we'll have to disagree on the merits of changing all of the oil at such low intervals. I think the risk of damage to the transmission by running the engine with lines disconnected is not worth the benefit of removing more of the fluid. If you want to drain more of the ATF it's easier (and safer) to just remove the torque converter plug (if possible).
I just drop the pan and change what comes out. Never had a problem.
Old 06-03-2005, 02:13 AM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
Oppy, I'm from the same school as you. Well said, and I agree. It might not remove as much total ATF, but there is less chance of blocking a trans line with sediment, etc. The best way, which I have done, is to install a drain plug in the pan. This way, you can remove more ATF, more often. For example, you can simply empty the pan, once every year,whether it needs changed or not, and replace with fresh ATF, full of additives etc. Then, about every 4th year, pull the pan, and do a complete change with a new filter (screen). With the trans drain, it makes the process easy, as the pan is light and empty of any ATF. Also, many transmission shops will drill and install a permenant drain bolt, for around $20, including the cost of the drain bolt + labor.
Old 06-03-2005, 06:31 AM
oppy's Avatar
Somebody agrees with me?? That's a first!
Well said Ed - couldn't agree with you more!
Old 06-03-2005, 02:02 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Once every 100k or so, or when it looks 'bad', whichever comes first.
Though I'm planning on switching to a 50k schedule and installing an auxiliary filter, knowing that E4OD's are a tad expensive.
Old 06-03-2005, 03:14 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
My methodology is to change it when it starts to change color or smell. Or when the manual says to change it, whichever comes first. Plus, always use exactly what the manual says to use.
If there's a torque converter drain, always do that too. Also, just change the filter when you're in there. Just like engine oil change, you always change the filter.
Need help with tranny fluid change on '94 F150! zbs60 Clutch, Transmission, Differential, Axle & Transfer Case 22 03-02-2017 08:35 PM
Tranny Fluid Change Interval Truckpilot1329 2009 - 2014 F150 13 07-16-2015 10:11 AM
2004 F 250 ext. cab super duty gas 5.4 snowmobile mike 1999 to 2016 Super Duty 3 11-30-2013 07:07 AM
TorqShift Maintenance schedule Tom 1999 to 2016 Super Duty 8 09-11-2009 06:24 PM
Escape Maintenance Schedule?? tonyford Escape & Escape Hybrid 23 01-08-2006 08:44 PM
Tags
atf, change, e40d, f150, f250, f350, fi50, filter, fluid, ford, interval, oil, psd, replace, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
