how often do you change your transmission fluid? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-16-2005, 10:32 AM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
Interestingly, though Ford recommends 30K fluid changes, they don't require the filter to be changed that often. The standard "filter" is really more of a screen.
IMHO, the best procedure is to install a pan drain and an in-line auxiliary filter (Ford #XC3Z-7B155-BA). This allows for easy fluid changes and better filtration, as well as easy changing of that filter. If you are blessed with a torque converter drain, you can do a very thorough job, but otherwise you can just do it more often.
  #32
Old 06-16-2005, 10:44 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
Regardless of the drain plug THIS procedure will change about 95% of the fluid. I've used it several times. It's easy and works great!
  #33
Old 06-17-2005, 10:12 AM
Thought I might add that the auxiliary trans filter I mentioned goes in the cooler return line, where it's easily changed.
Personally, I feel a bit uncomfortable pumping out the transmission fluid, but I guess I can't really say that it could do any harm.
  #34
Old 06-17-2005, 11:44 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
I'd put in the line that goes to the cooler, not the one that returns from it. That way, it prevents solid material from entering the cooler.
  #35
Old 06-20-2005, 03:33 PM
That's a good idea if it is a new cooler, but if the cooler has been there for a while there already is junk in it and you want to keep that junk from getting back to the trans.
  #36
Old 06-27-2005, 11:31 AM
Well, that's where Ford tells you to put it when you buy the installation kit: I didn't really give it much thought. Casey probably stated the reason..
  #37
Old 08-21-2005, 12:07 AM
willbd willbd is offline
willbd is starting off with a positive reputation.
Do you have a transmission temperature gauge? If not I would get one and change the fluid by how hot and many miles you drive. If the fluid stays below 165 degrees than change the fluid every 20k to 30k. Every 10 degrees of temperature take away 5K from the change interval. This if for normal ATF you can run synthetic ATF @ a higher temperature and longer change intervals.
  #38
Old 08-21-2005, 03:12 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Quote:
the filter cannot take the extreme heat of the input line. thats why you use the output line it runs cooler.
  #39
Old 08-21-2005, 03:43 PM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Quote:
You are a new user so you probably do not realize that the chart to which you refer has been bouncing around these boards for years. It wasn't accurate or correct 30 years ago or so when it was published, and isn't even close to being correct in 2005.
Per Ford specifications, normal operating range for the 4R100 and 5R110 is 51*F to 248*F.
  #40
Old 08-21-2005, 03:50 PM
jschira's Avatar
Quote:
Hmmm, maybe I should tell mine that it should break, but it has been doing so fine sitting in the input line, I'm not sure that I want to disturb it.
The filter maker makes the following installation recommendations:
Quote:
1. On new vehicles (less than 5,000 miles), it is recommended that the filter be installed on the cooler supply side to protect the cooler from contamination. On in-service vehicles (more than 5,000 miles), the filter should be installed in the return line from the cooler to the transmission. On any vehicle that has experienced any transmission difficulty, the filter should be placed on the return side.
See here:
http://www.emergingent.com/magnefine...ation_page.htm
  #41
Old 08-22-2005, 10:31 AM
Nonsense. Heat is not an issue since the tranny would be toast in a short time anyhow if the oil were *that* hot. And I think erngine oil can be a little hotter, yet I have yet to hear a single case of "filter overheating"....
The issue is whether one wants to ensure that the cooler is not contaminated (so the filter is installed before) or one wants to ensure that the pre-existing contamination from the cooler doesn't travel back to the tranny. (so the filter is in the return line)
Since the filters carried by Ford are normally installed after some work on a tranny (flush/rebuild/replace/etc.) it makes perfect sense to put them after the cooler if the cooler is not replaced at the same time.
However, if one has an aged tranny (mine is over 170k) -- it makes a lot more sense to put the filter before the cooler, so if the the tranny breaks down, the filter will hopefully protects the cooler. If, or when, the tranny is replaced, the filter should be moved after the cooler, though, if the old cooler is to be kept in the car.
  #42
Old 08-22-2005, 12:02 PM
Makes sense. I just followed Ford's directions, without knowing their reasons.
  #43
Old 08-22-2005, 01:14 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Why not put a filter before AND after the cooler?
  #44
Old 08-22-2005, 01:56 PM
jschira's Avatar
Quote:
It reduces flow through the cooler too much. Not a good idea.
  #45
Old 08-22-2005, 09:40 PM
mrxlh's Avatar
mrxlh mrxlh is offline
mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.
On a gasser with not alot of pan volume, 15,000. On my PSD 30,000. Oil is way to cheap to sacrifice an AT. You also get a much better picture of what is going on inside you tranny if you pull the pan every 15,000. It's a lot cheaper to correct a problem, IE, clutches wearing, than wait til it grenedes to do a total rebuild. I will argue that a flush is the worst possible thing you could do to an automatic. Some people will swear by them, thats fine, keep on keepin on, if you change it every 15,000 you never have to worry about how much you got out.
Ryan
Tranny Fluid Change Interval Truckpilot1329 2009 - 2014 F150 13 07-16-2015 11:11 AM
2004 F 250 ext. cab super duty gas 5.4 snowmobile mike 1999 to 2016 Super Duty 3 11-30-2013 08:07 AM
TorqShift Maintenance schedule Tom 1999 to 2016 Super Duty 8 09-11-2009 07:24 PM
Escape Maintenance Schedule?? tonyford Escape & Escape Hybrid 23 01-08-2006 09:44 PM
Need help with tranny fluid change on '94 F150! zbs60 Clutch, Transmission, Differential, Axle & Transfer Case 20 02-17-2003 11:03 PM
Tags
atf, change, e40d, f150, f250, f350, fi50, filter, fluid, ford, interval, oil, psd, replace, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
