1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Where's the radiator drain plug on my '97 Expedition?
Old 05-31-2005, 09:17 AM
wavinwayne's Avatar
wavinwayne
wavinwayne is offline
Question Where's the radiator drain plug on my '97 Expedition?
I want to drain & re-fill the coolant in the radiator of my '97 Expedition 4.6L. Does my Expy's radiator have a drain plug on the bottom? If so, how do I get to it? If not, is it ok to simply remove the lower radiator hose & drain it that way?
Thanks in advance for you's guys' help.
Old 05-31-2005, 12:15 PM
PaulC's Avatar
PaulC
PaulC is online now
The drain is on the passenger side of the radiator, on the back side near the bottom. It's made of plastic, and has a large flat "handle" It does not look like the old fashioned metal pet*****.
Old 05-31-2005, 12:32 PM
wavinwayne's Avatar
wavinwayne
PaulC,
Thank you very much for your help!
ww
Old 06-07-2005, 07:40 AM
wavinwayne's Avatar
wavinwayne
PaulC,
It's me again; I'm still having trouble finding the drain plug onmy Expy. It doesn't seem to be where you said it should be. I see some sort of plug on the lower right side of the radiator. What I mean by lower right side is: It's not on the bottom of the radiator & it's not on the back of the radiator. It's on the passenger side of the vehicle & on the side of the radiator.
The "plug" I see is an off-white, sort of yellow-ish colored plastic hex head screw of some type. The hex head is approx. 1/2"-5/8" tall. Am I looking at the right thing?
Thanks in advance
Old 06-07-2005, 12:14 PM
PaulC's Avatar
PaulC
PaulC is online now
Wayne, my bad. Apparently I was confusing another vehicle of mine with the Expy when I wrote the first post. I just popped the hood of my Expy and looked. It's an off-white plastic hexhead nut positioned on a very short plastic tube on the lower back side of the radiator.
baja2000
11-19-2014 01:37 AM
DMTR
Aerostar
31
01-31-2014 06:31 PM
Avanti
Escape & Escape Hybrid
07-16-2013 01:37 PM
ilvtravln
04-14-2012 09:05 PM
cliffhanger45
07-02-2011 03:09 PM
Quick Reply: Where's the radiator drain plug on my '97 Expedition?
