Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-31-2005, 01:34 AM
61StationBus 61StationBus is offline
Garage is empty, add now
61StationBus is starting off with a positive reputation.
61 econoline bus gearing
Hello--I am hoping you guys can point me in the right direction here. 15 years ago my father purchased a 1961 econoline station bus with a 144 and 3 on the tree. He replaced the engine with a 200 and a C3 trans. About 6 years ago he passed away and the van became mine, and i just got it running. here is where my problem is...the rear end and trans are both geared low so my top speed is about 35mph. I have a 9" out of a 67 HD econoline, but it needs complete brakes and seals, and i wanted to keep the original since it is in perfect working order. I was hoping that rancheros or falcons may have the same rear end so I could just do a simple gear change. I have also heard that ford ranger rear end's are a perfect fit...is this true? Any information would be greatly appreciated---I really want to start driving this beautiful original condition van! Thanks!
  #2 (permalink)
Old 05-31-2005, 09:00 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
Talking
sadly, only thing that is a direct interchange is an econoline, 1961-1965 with the small rearend. the 9 in will fit under the truck, but there is not a cross over u joint for the driveline.
gear change requires a special tool to spread the housing, the carrier is wider than the housing is.
wish i could be a little more positive, but unfortunately ford didnt help us out a whole lot on the econo's.
jim
you have a private message
  #3 (permalink)
Old 05-31-2005, 09:10 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
My 64 econo truck has a 9 inch rear in it and it came stock. I also have recently aquired a pre 65 van body will a 9inch rear also.
You consider seeing if you could reinstall a standard back in. That would probally help. It maybe difficult to find the older trans,but they are a round. At 35 mph it seems like you are not getting out of 2nd. Is the tranny working up to snuff. If so it might be that you will have to bite a bullet and change the gears to get your speed up.
  #4 (permalink)
Old 05-31-2005, 11:29 PM
Smile
Sad to say that the 3-speed trans and steering column/shifter are long gone along with the clutch pedal. The C3 in it shifts into all 3 gears no problem....just way to quick. the only problem with it is a leak around where the shifter selector goes into the trans body. With the 200 in it the driveshaft is only about 18 inches long...it was a little 10 min. cut and weld that didn't need balancing, and I thought the 9" rear end yoke and driveshaft line up...but I don't know for sure. Thanks for the Help so far!
  #5 (permalink)
Old 07-17-2005, 05:59 PM
briank briank is offline
briank is starting off with a positive reputation.
Don't know if you are still having problems. But I had a 65 HD that had a 9 inch rear in it. We took out the 200 and put in a 78 Granda 250 CID with auto and our drive shaft was about 18 inches or less. Everything line up. The original rear end had 4:11 gears so it was great for light to light racing. Changed that out with 3:25 gears out of another 9 inch with no problem. Wish I still had that van.
Brian
Tags
1961, bus, econline, econoline, inch, rear, tickets
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
