engine wont start tried the obvious
Old 05-30-2005, 11:13 PM
bonesdungeon's Avatar
bonesdungeon
bonesdungeon is offline
I have a 97 f250 with an edge evolution. Last week it died while exiting the highway,and wouldn't restart.
I replaced the cam position sensor a couple of weeks ago trying to solve a rough idle problem. I went back to stock setting on programmer.
I replaced high pressure pump and it ran great for a couple of days.Then it dies on the road at 60 mph again. Found a shorted wire at the sensor on the high pressure pump, fixed it, truck ran for a day.Now it will start and run for about 15 minutes,then die. Let it set for a few hours and it will do the same again.Acts like its running out of fuel,but its got plenty of fuel in the filter resivour(checked fuel pump) replaced PCM no changes,and yes I even checked the oil level! Im really frusterated and this is my work truck ,its killing me
Old 05-30-2005, 11:18 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
How about a failing IDM?
Old 06-01-2005, 07:50 AM
bonesdungeon
ive been wondering about that or heard of possiblre valve cover gasket problem due to wiring in them.neither one is cheap to just "try"
Old 06-01-2005, 12:04 PM
touchofgrey's Avatar
touchofgrey
touchofgrey is offline
Bones......you didn't mention if you checked for error codes. Were there any?
Old 06-05-2005, 09:58 PM
bonesdungeon
wouldent show any codes
Finnally broke down and took it into a shop i was told is reputable.
they found the problem,IPR valve in HPOP is dumping pressure for some reason either bad "O" rings or faulty valve.hopefully I'll have my truck back by Monday.thanks all for your input
Bone
Old 06-13-2005, 11:26 AM
KC0FHM's Avatar
KC0FHM
KC0FHM is offline
Bad IPR
OK for month's I've Been trying to trace a problem similar but not exactly like yours, the truck just wouldn't start cold even on a 90 degree day but I could plug it in and it starts every time, checked all the usual Glo plugs cycler HPOP leakdown everythings OK except the truck Idles rough and it just doesn't seem to have the HP it should and it won't start cold.I've also recently noticed it occasionally stumbling when I get to a stop sign, but it has always kept running. since the truck needs a 1000# higher pressure to start cold than it does hot I've been leaning toward a an IPR problem since this problem came on gradually I'm more suspicious of the O-rings than the reg itself, but it's the same amount of work to change the O-rings as the entire unit so I think i'd change the whole thing.
It would also maybe figure to put a guage on the hig pressure oil rails to see what they're actually doing before spending the $250 ford wants for this part, (intl's part is only $50 less but they don't seem to know anything about those O-rings) that kinda scares me as I hate to get things apart and find out I have the wrong part or not all of them.
Does anyone here know where to get the proper test fittings to do this
Thanks Ron West
Royson12
49
03-15-2014 04:50 PM
Hammerhead24
2004 - 2008 F150
04-18-2010 11:44 AM
steadtech
03-19-2010 07:07 AM
Paco_Jones
10-11-2009 07:14 PM
Chickenmantoo
Bronco II
05-06-2002 09:55 PM
Quick Reply: engine wont start tried the obvious
