Boss's lightning doesn't start - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 05-30-2005, 10:05 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
02 lightning, completely stock.
40-45k miles on it I guess...
I turned the key and get a click from the solenoid on the firewall, but no turn from the starter. Battery is good, wacked the starter with a hammer with key turned in start position didn't work...
Any ideas on how to get this thing running? I played with the neutral safety switch and didn't get anything. I noticed the battery light flickered a little with the key in the start position.
Just clicks and no turn in starter.
Old 05-30-2005, 10:22 PM
Percys Armory's Avatar
Percys Armory Percys Armory is offline
Percys Armory is starting off with a positive reputation.
fuel shut off?
Old 05-30-2005, 10:33 PM
The fuel shut off would stop the starter from turning the engine over?
Old 05-30-2005, 10:43 PM
Im just trying to jumpstart other ideas. low battery? Did you check that?
Old 05-30-2005, 11:32 PM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
All the way in gear? brake safety switch? Check the cruise control shutoff switch on the master cylinder.
Old 05-31-2005, 08:06 AM
I tried it in N or P...brake on or off...fiddled with the alarm buttons...
I had him turn all things that would take power, heat, lights, radio, etc and when he tried to start it the lights didn't dim...I don't think it's a bad battery just by observation...I feel as though it's something else.
I'll check this cruise control shutoff deal...
Old 06-02-2005, 05:40 PM
update? 8910
Old 06-02-2005, 05:48 PM
It's stuck at our office, I havn't been there since I made the thread, but I'm going in tomorrow...
Only thing I can check is the cruise control shutoff switch I guess...other then that w/o me really tearing into it I can't figure it out. Not much I can do w/o it being on a lift or in my garage. He will probably end up having it towed.
Old 06-02-2005, 10:54 PM
351M's Avatar
351M 351M is offline
351M is starting off with a positive reputation.
The hitting the new style starters won't work, My guess is that could still be what it is.
Old 06-03-2005, 12:04 PM
Out of curiousity, why doesn't it work?
Old 06-03-2005, 10:07 PM
351M's Avatar
Well, correct me if I'm wrong, but aren't the '92+ Fords all permanent magntet style? You usually wind up doing more damage then good to then trying that. I had a Dodge one die and hitting it never worked but then once I talked to a shop they also said that they have never been able to get any newer starter to work with that trick. I can't for the life of me remember anything other than the magnets crack really easy, there was another reason but I can't remember at the moment.
Old 06-04-2005, 10:54 AM
Well, typically if the starter needs to be hit for it to work, it's time to change it out anyway.
I've used the hit trick on my 95 and it works...
Old 06-04-2005, 02:05 PM
sgarcia sgarcia is offline
sgarcia is starting off with a positive reputation.
did you ck if the solenoid had power on the starter side when it clicked?thats one way to find out if it's really the starter or your solenoid.this is a common problem with Fords.
Old 06-04-2005, 02:25 PM
did you check the thingy by the firewall?
Old 06-04-2005, 02:53 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
Did you check the solenoid on the starter itself? All 92-up trucks have 2 solenoids....
Help! '84 F150 starter won't stop turning shadetree enthusiast 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-18-2014 04:39 PM
Key in start no crank mcerchio 6.0L Power Stroke Diesel 9 12-31-2013 04:07 PM
55' F100 Starter, Ignition, Solenoid....Hmmmm JoeSwing78 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 08-23-2013 06:53 PM
1993 E350 Motorhome - Start System E30tdf 1968-2013 Full Size Vans 10 04-07-2012 10:49 PM
Strange Starting Problem mulik51 Bronco II 50 06-17-2005 12:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
