Big Trucks
Old 07-17-2005, 07:30 PM
workingdog's Avatar
workingdog
workingdog is offline
Thanks so much for all the info. Found the tag in the glove box. 14,000 pounds - definately an F5- right?
Peter
  #47
Old 07-17-2005, 08:05 PM
1949f6's Avatar
1949f6
1949f6 is offline
I have a 1949 F6. With the 254 and synchro_silent. It also has a brownlipe auxilary transmission.I have 8.25*20 all around. The paint is Okay but there is major rust.
  #48
Old 07-17-2005, 11:16 PM
ndakotan's Avatar
ndakotan
ndakotan is offline
Big Truck
I just got a 1959 F-600 here in Tucson AZ. Used to be a city truck, has the 292, 2speed rear, dump bed, half the glass it needs, plenty of rust,flaking white paint someone sprayed over everything,the widow maker wheels, all is perfect by me-lots of work to do...
  #49
Old 07-18-2005, 12:56 AM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
That's a very cool truck..... you should get it back!
There's nothing like a BIG Ford...I love to drive up next to a newer lifted F350 dually and be at the same eye level as them!!
Regards,
Rick
Originally Posted by etcetera
A little late to the game, but I had a 1964 F-500
http://www.ericclaussen.com/f500.html
The guy who has it needs to sell it, if anyone's interested.
  #50
Old 07-18-2005, 01:21 AM
etcetera's Avatar
etcetera
etcetera is offline
I'd love to get it back, but my wife absolutely hates it. She's pretty much let's me do what I want, so to keep it that way I got rid of it.
It sure turned lot's of heads.
Eric
  #51
Old 07-18-2005, 12:02 PM
HT32BSX115's Avatar
HT32BSX115
Yeah....I know what you mean....I get a LOT of second looks at mine!! (in the gallery)
I even got my wife to go for a ride in it (ONCE!!) It's not restored yet and her problem is that it doesn't have seatbelts...I reach for the shoulder harness everytime I get in it! I'll probably put a split bench in it that has shoulder harnesses built right in.
(btw....have you tried FEDORA CORE 4 yet? RH7.x, 8.x, 9... is so seriously outdated!! I've been using SUSE Linux pro for several years as you can see by my Avatar.....I don't want to hijack this thread so just respond via the personal message if you like!)
Cheers,
Rick
Eric
  #52
Old 07-26-2005, 08:23 PM
John2Thomas's Avatar
John2Thomas
John2Thomas is offline
1949 F-6
All original, V8, minor rust and only 12000 miles. It's an old firetruck.
  #53
Old 07-27-2005, 11:57 PM
48 Ford F4's Avatar
48 Ford F4
48 Ford F4 is offline
Smile F6 firetruck
Welcome There's more of us big trucks all the time. Post a picture when you can.
48 FORD F4
  #54
Old 08-04-2005, 10:46 PM
Marmon's Avatar
Marmon
Marmon is offline
Originally Posted by HT32BSX115
2 questions......have you thought about a 4x4 conversion for the F-600, could you provide me with the model numbers of the Clark 5 speed and the Eaton 2 speed rear end?
I believe the Eaton rear end would fit my 55 F-600....I have also considered a 4x4 conversion for my F-600 if I could locate the parts or another truck.
Thanks,
Rick
Hi Rick,
Regarding your questions about my 1959 F-600: it has a 292 V-8, a Clark 250V five speed transmission (very deep 7.08:1 first gear) and an Eaton 13602 rear axle. The transmission is a little odd in that it is built with synchro's only on forth and fifth gear, the others require double clutching. The axle is an electrically shifted two speed with ratios of 6.33/8.81:1 (pretty low gearing - tops out at about 60 mph).
I've done 4x4 conversions on light trucks before, but to convert this truck to four wheel drive would require a custom built (re: expensive) front driving axle in order to get the proper tread width, weight and torque capacity, brake drum size, wheel hub bolt pattern, etc. It would seem to be much simpler and cheaper for you to buy a similar year Marmon-Herrington/ or Napco/ Ford conversion, and transfer the driveline parts.
Bud
  #55
Old 08-05-2005, 03:01 PM
56T700's Avatar
56T700
56T700 is offline
Dad has a 56 T700. The truck is restored pretty much stock with a home made tilt bed for hauling his 28 Fordson in parades. Photos are in gallery.
  #56
Old 08-05-2005, 08:40 PM
etcetera's Avatar
etcetera
etcetera is offline
Another 2wd axle option that looks really nice is GMC school bus axles. My 64 F500 had axles from a 60's GMC school bus. A tad wider, so the stance was better looking, and they were for sure rated for more weight. 2 speed rear, just like stock.
For 4wd a 5 ton military axle might fit the bill, and it just might be wide enough. You could buy a pair on ebay for $$$, or if you have the space, buy a surplus 5 ton truck for $800-1200 dollars. A 2.5 ton rockwell might cut it too. I think there's a good chance it's the same bolt pattern.
Eric
  #57
Old 08-05-2005, 11:20 PM
HT32BSX115's Avatar
HT32BSX115
I do need to find a 2 speed axle for sure. Most of them were 5.83/8.xx:1 My single speed is 6.83:1 (Timken axle) and requires something like 3600rpm for 60mph! It just screams! Sounds like it's coming unglued!
I am currently looking in Western WA for a 2 speed if anyone knows of one around here. I want to be able to use my brake backing plates/brakes etc(everything in there is new).
I'm not all that hot to put 4x4 in it actually....It would be nice but like someone said earlier it would be MUCH easier to find a MH truck all ready to go...
I have thought about military axles...but they might be a little BIG!
Eric
  #58
Old 02-08-2006, 07:09 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
hey f6guy here i own a 51 f6 thats primer red and bitchen, may have a 2speed rear up for grabs out a 50 model
  #59
Old 02-08-2006, 07:42 PM
John - NNY's Avatar
John - NNY
John - NNY is offline
1948 F-7
I have a 1948 F-7 stake bed. The bed is not original. It is 16' long made out of cherry. Has the original 337 flathead and 5 speed trans. Restored but the P.O. didn't keep up on the mechanical stuff. I am waiting for spring so I can start working. Temps outside are in the low 20's. It's hard to flush the radiator when the water freezes.
John - NNY
  #60
Old 02-08-2006, 08:59 PM
HT32BSX115's Avatar
HT32BSX115
Hey that sounds good. Do you know what the ratios are and where are you?
Quick Reply: Big Trucks
