JP8 / JetA fuel in a 6.0???
Thanks marspec, I didn't consider the lubrisity. I had heard years ago that using jet fuel would work fine and actually increase performance but had never seen any proof of any kind. Maybe the new diesel engines are more critical on fuel I suppose. I am in contact with someone who is trying to get rid of 150 gallons of jet fuel, unsure which type, but think it is JP8. Thought it might be interesting to use in the 6.0 and see if it does good stuff. Sounds like it might be a bad idea though unless one knew how to formulate it for certain protections. Warranty could be an issue as well eh?
In my time in the Marine Corps, we used the same JP-5 in the Detroits (generators, hydraulic test stands) as we did in the jets (F-18 Hornets). I never heard of one having any problems b/c of it, but that doesn't mean there were none. It is a little less lubricating, especially the JP-8. I don't know if the 6.0 will like it, it is very fuel sensitive as it is, good luck if you try it.
I know that the Army uses JP-8 exclusively now (with few exceptions). We use it in everything from HMMWVs, to generators, to tracked vehicles, to stoves. I always wanted to see how it would work in the 6.0 considering I had 7 2500 gal tankers in the motorpool full of it. Do a search for JP8 and you'll find more than you wanted to know....except how it will run in a 6.0
I ran Jet A-1 in my 6.0 for 9 months and had no problems. The truck seemed to like it better. I ran a 2-1 mix, 2 gallons diesel to 1 gallon jet. It should be noted that Jet A-1 has less heat energy per gallon than diesel, so one will so a performance decrease when running straight Jet. I had one guy that I worked with run straight Jet in his 7.3 and he turned up the pump pressure to get his power back.
I dont know i would love to hear the results.. I am kinda naieve in this area. i have a question though.. I live out by the everglades in south FL, and i frequent the glades with my buddies and they are running air boats and they run aviation fuel they call it..how is that compared to what your talking. Could this be run as well. what is the cost of the fuel? is it worth it.
Ryan
Ryan
The fuel you are talking about is probably 100 LL aviation gasoline. It is similar to premium gasoline, except with some added lead and lower vapor pressure so it won't evaporate as easily. It must not be run in a diesel because for all practical purposes it is like gasoline and not like diesel. Jet fuel is more like diesel because it has roughly the same boiling range.
Ok so how much is Jet Fuel and would it be a benefit to run it. Its not exactly available at your local startion. So unless you have access to it on a regular basis it seems like it could be a real pain in the butt to even get.. So that being said what do you think the adavantages would be of running it in our 6.0's if any and how much is it, like per gallon..
ryan
ryan
Jet A is alittle less than $4.50 per gallon. What you would have to watch out for is the additive that is sometimes premixed in the fuel to stop water in the fuel from freezing in the fuel lines. Very critical for aircraft!!! The name of one manufacturer is prist. Now if I'm not mistaken it does raise combustion temperatures but how much I'm not sure. I have access to Jet A and have used it on occassion, not much maybe 5 to 10 gallons here and there, with no adverse affects.
Rob
Rob
Ok no adverse affects. But what are the advantages. You say it raises the combustion temp so maybe a hair more power? but holy geee 4.5 a gallon it would cost about 130plus bucks to fill my 29gal tank, Is it worth this.,When you ran those 5 gallons here and there did you notice any difference in performance that would warrent 4.50 a gal or not even performance. is there an Advantage to maybe longevity or maintenance. for that price. Kinda like it is when using a good oil.?
ryan
thanks for the answers just interested in this but know not much...
ryan
If there was any gains I really did not notice them. I used Jet A without the additive (you have to drain about 5 to 10 gallons from a sump drain on each fuel truck to check for water in the tanks, very rare). It is free for me, thats why I tried it. Then I came to FTE and got freaked out about this engine and stopped doing it. Free fuel or possible new motor? Trust me it is a hard decision. I would definitely not pay for iteven if there was alittle gain, cost outways the gain for sure. Hope this helps.
Rob
Rob
