??? about the EGR plate???
Hi there I am trying to figure out this problem.......
I just put on a new Holley carb on my 351 m and I am still having problems tuning it. Is there a problem if I am using the EGR plate that the carb sits on but it has a plate over the back portion and everything is disconnected for the EGR system.........
Will it be better if I just take off that EGR plate and can I just bend the kickdown rod to fit on the Holley carb....??????????
If you simply lose the EGR valve and don't change anything else, you may run into EGR ping. Engines with EGR need more timing advance, so when you take out the EGR without readjusting the vacuum advance, you'll get an effect similar to spark knock.
In my opinion, you should leave the engine with a working EGR system. The 400\351m were basically made for EGR and it takes a lot of annoying trial and error to run properly without EGR. If you remove the EGR plate entirely, you'll be dealing with hot exhuast gas underneath the carb which is no good. Many will tell you that you won't see much of a difference in performance with or without EGR, and I happen to be one of those people. In my opinion, losing EGR isn't worth the hassle.
bullnose1985
16
10-15-2017 03:04 PM
Targa185
02-10-2015 02:04 AM
atomicjoe23
03-10-2010 01:03 AM
