I am trying to find out what the load capacity is of a certain 1991 E350 wheelchair van, model S31. I want to at least know if it exceeds 1500 lbs. Thank You
The stock van should weigh about 6500lbs, subtract that from the gvwr on the door sticker. E350's sometimes have gvwr as high as 9500lbs that would give you 3000lbs capacity.
