E 350 Van load capacity - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 05-25-2005, 05:03 PM
khorn khorn is offline
khorn is starting off with a positive reputation.
Question E 350 Van load capacity
I am trying to find out what the load capacity is of a certain 1991 E350 wheelchair van, model S31. I want to at least know if it exceeds 1500 lbs. Thank You
Old 05-25-2005, 05:35 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
The stock van should weigh about 6500lbs, subtract that from the gvwr on the door sticker. E350's sometimes have gvwr as high as 9500lbs that would give you 3000lbs capacity.
Old 05-26-2005, 07:32 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome khorn, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
1985 E-150 towing VanyaWatson Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 1 07-17-2016 07:34 AM
E250 Cargo Van drpianoman Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 3 09-03-2015 06:54 AM
Using different size tires on an E-350 van - drawbacks? geoffhazel 1968-2013 Full Size Vans 14 03-15-2015 04:36 PM
Load Capacities clintusaf 1999 to 2016 Super Duty 42 05-29-2010 06:57 AM
E-350 Towing Capacity gbraley Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 1 03-06-2005 06:46 PM
Tags
1997, 2005, 2009, 350, capacity, decoder, decoding, door, e350, f350, ford, gvwr, load, sticker, van, vin, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
