Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-25-2005, 11:28 AM
thesprocket26's Avatar
thesprocket26 thesprocket26 is offline
Garage is empty, add now
thesprocket26 is gaining momentum as a positive member of FTE.
Propane Info setup
Hey ya'lls. I have a Impco 425 carb and two other thingys. One of them flows water and gas through it and the other has a VFF30 number cast on the top side. What are these things? Is there some diagrams or instructions for installing propane I could get? Also, what kind of fuel lines/hoses do I need to buy? Do they have to be special? I'm building a propane 400 motor for my 67 f100 4x4. Thanks.
__________________
I will take good american steel and iron over plastic and airbags any day
  #2 (permalink)
Old 05-25-2005, 12:40 PM
351M's Avatar
351M 351M is offline
1986 Ford F-150
351M is starting off with a positive reputation.
Go to www.propaneguy.com, it sounds like you have the main 3 components though. 425 is the mixer, the part that flows water through it is the regulator or vapourizer, what ever you want to call it, and the other should be the lockoff valve (fuel shutoff) This will all have to be certified before you can fill it as well.
Tags
425, ford, propane, setup, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
