Is anyone here familiar with the 4 cycle string trimmers. I know Ryobi makes a couple that are sold under their name and also the Troybuilt name. Sears sells one but I'm not sure who makes it. I just wonder how they compare to the 2 cycle ones.
I've got a Troy Bilt 4-cycle that I've had for two years. Previously I had Homelite and Ryobi 2-Cycle trimmers. So far, I like the Troy Bilt better than the 2-Cycle units. It doesn't need to be run wide open all the time to do the job. No oil smoke. Is is a bit heavier than comparable 2-Cycle units however.
So far I'm pleased - however, as always, individual results may vary.
Guess we should get used to the idea of 4-cycle small engines. The two-stroke engine could be a thing of the past before long due to the smoke and noise they produce.
Can you even buy a two-cycle motor in California anymore? I read somewhere they either banned them or were considering a ban.
Yeah they are still all over the place here. In fact I'm currently shopping for a BIG brush trimmer to beat back the blackberries and manzinita and so far the only good ones I've found are 2 stroke 40cc and up. If anyone knows a good 4 stroke one of these I'm all ears. You might have heard about 2 stroke watercraft here. The way I hear it is they are trying to remove all non-modified 2 stroke engines off of the lakes here and have done so already to some of them. Lake Tahoe is one I think, since its landlocked. 2 stroke watercraft manufacturers have countered with a modified 2 stroke that somehow keeps the excess oil and smoke out of the exhaust, so these are still allowed.
Personally I hate the smell of dozens of 2 stroke engines on the water while I'm out there enjoying my day. BTW, if the environmentalists in this state had their way we'd all have to walk or ride bikes everywhere and there would be no electricity. This state is ALWAYS considering some kind of ban or other...
__________________
Just bought a 76 F100 4x4 shortbed
"There are 10 kinds of people; those who understand binary and those who don't!"
I highly recommend STIHL also. I have a model 55, and I know it is not a 4-cycle, but it is one darn good trimmer. I liked it so much that there was no question what brand I was going to buy when it came time to getting a blower.
About three years ago I had a Honda four stroke powered brush cutter/weed eater. It was a nice big commercial type unit. I loved it. It had the seven foot straight shaft with the wide handle bar style handles. Easilly maintained and more than enough power for even the toughest jobs. I highly recommend the Honda units. I'll never go back to the two strokes for this type of equipment. I wish I still had that one. I let it go with the other commercial equipment when I sold the business.
i have the stihl fs110rx, its a commercial grade trimmer. its a 4mix type, a 2 cycle engine with valves. this thing goes through knee high brush with less than half throttle. http://stihlusa.com/trimmers/FS110RX.html
Ive got a Honda trimmer. I like it. Its quiet, doesnt vibrate much and not having to mix gas/oil is nice.
Ive got the 25cc model and its really no heavier than the Echo 2-cycle trimmer I used to use.
However, the Honda was VERY expensive. It cost me over $300. For the money, I would buy either a Ryobi or Yard-Man 4-cycle trimmer (they are basically the same thing). You could get either of those for under $200, heck if you bought one towards the end of summer you could probably get one on sale for under $150.
Octane
__________________
'99 Ford F-150 regular cab longbed 4x4 Off-Road with 5.4L V8
190,000 miles
Support USA manufacturing!!!
Earth first. We'll worry about logging the other planets later.
i believe i paid $329.95 and tax. if you get the poly head instead of the string it will cut small twig trees. http://stihlusa.com/trimmers/blades.html
you can only use the string or poly cut head on the FS110RX, if you want to use a steel blade or any attachment you need to get a FS110R.
the FS110RX has a hollow shaft while the others have a solid shaft, but i believe that stihl has a lifetime warrenty on the shafts.
If you like 2-stroke trimmers, maintain yours well and hang on to it because their days are numbered due to emissions regulations.
I personally don't mind if they do away with the 2-strokes. It is an extra pain to mix the oil and gas. The primary advantage of the 2-stroke was its power to weight ratio. With the advent of a cleaner, lighter 4-stroke engine, the 2-stroke's sole advantage is lost.
I am not an environmental fanatic by any stretch of the imagination, but it only makes sense that if you can do the same job in the same amount of time with the same (or less) effort, why not do it with as little environmental impact as possible?
__________________
97 250 PSD Ex Cab Sd 4X4 ZF5 135k
6637 in, 4" stainless ex
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
Marinco block heater tap
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
SiriusXM music & talk
Hula HP
EBPV brake
"I tried being reasonable. I didn't like it."
I've had a few 2 stroke trimmers. They were major Pains In The Arse. Hard to start, hard to keep running, and hard to keep tuned correctly. Mixing gas / oil was a hassle.
Then I got the Ryobi 4 cycle. Works great. Starts exceptionally easy, runs good, idles good, never dies. Plenty of power.
