Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-24-2005, 09:54 PM
Customz's Avatar
Customz Customz is offline
Garage is empty, add now
Customz has a good reputation on FTE.Customz has a good reputation on FTE.Customz has a good reputation on FTE.
MSD: Digital Propane Injection
Anyone tried the product?
They claim it works well w/ tuners and adds up to 70 HP. It also increases the range of the vehicle (assumably because you are burning 2 sources of fuel and measurimg MPGs off diesel fuel alone)
Is this product for efficiency, lower EGTs or increased power?
__________________
2006 F-250
  #2 (permalink)
Old 05-25-2005, 10:36 AM
Mark at DPPI Mark at DPPI is offline
Mark at DPPI is starting off with a positive reputation.
Customz,
It's actually for all three. It's gets the average diesel 60-80 HP, increases MPG (if you drive like you want MPG anyway), and cools EGT's 100+ degrees on average. It's also the only system that allows the user to reprogram the propane curve based on what "other" mods they have or don't have etc. Quite a product overall.
Mark @ DPPI
__________________
url]
  #3 (permalink)
Old 05-25-2005, 03:21 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Now I'll buy the power gains, it does add a good kick...
But as far as lower EGT's, the BS meter is creeping up here...my TorquePro most certainly does not lower the EGT's, and I have never seen nor heard of any propane system that actually does. Logically, it cannot. People seem to have this misconception that propane is a catalyst with diesel fuel- chemically, it is not. The faster burn rate does assist with burning off all of the diesel, but you are still adding fuel- more fuel = higher EGT.
On a good note, of all the propane systems, this one does appear to be a very quality product.
Vic, you got any input on this one?
  #4 (permalink)
Old 05-26-2005, 12:34 AM
Fastest1 Fastest1 is offline
Fastest1 is starting off with a positive reputation.
The propane could have a lower burn temperature/btu's and cool it down , I would think.
__________________
04 F250 CC 2wd Auto 3.73, Edge w Attitude (long gone) and blown tranny @ 34000mi. Arp studs, First Coast Diesel egr cooler delete manifold and up pipe. Sct X3 and powershot 2000 Propane.
  #5 (permalink)
Old 05-26-2005, 05:16 AM
Crash687's Avatar
Crash687 Crash687 is offline
Crash687 is gaining momentum as a positive member of FTE.
look at the notes under the picture of the system it states to install a pyro guage as exhaust temperatures increase.
http://www.msdignition.com/pdf/dpi.pdf
http://www.msdignition.com/2005/2005_13.htm
__________________
FTE "the best, why mess with the rest?"
just so you know what time it is
Help cure Cancer
'05 F-350 PSD work truck
If electricity comes from electrons, does morality come from morons?
  #6 (permalink)
Old 05-26-2005, 08:29 AM
powershotone powershotone is offline
powershotone is starting off with a positive reputation.
If you do not use exorbitant amounts of propane to accomplish what a small amount will do, which is simply help burn the diesel that is present more completely...., then yes you can actually see lower EGT's. .
Now mind you, this is not a tremendous drop by any means, usually only about 50-100 degrees but it should not cause them to increase.
And yes, you are correct, propane is not "technically" or by definition a "catalyst" in the true sense of the word, but for lack of a better way to describe it's effect on the diesel fuel, it is used to explain what happens.
So while you are adding a fuel, the key is to not add a lot, (i.e. control the amount) so that you burn it (the propane) completely and more of the diesel along with it, such as with a system that is variable and controls and meters the flow of propane by a constant perimeter such as ...........boost pressure
Gauges are a good idea, regardless.
__________________
2004 Harley 6.0, Powershot 2000 propane, Diablo Predator, exhaust, etc.
1999 F 250, ATS chip, Powershot 2000 propane, etc.
Tags
2000, 73l, alternative, apply, diesel, digital, ford, fuel, injection, mpg, msd, powershot, propane, system, wwwmsd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
