TELL ME IT's TRUE??????
I believe I have my air intake choice narrowed down to two: AirRaid or Air Force One.....(any other proven, no tune required) air intake I'm misssing?
Anyway, I can't quite believe what the AirRaid rep told me. He said that the AirRaid is dyno proven, on an otherwise stock F-150 3V V8, for the following increases: +22rwhp and +50lbs torque?? WITH NO TUNE REQUIRED and the engine will not be throwing CEL codes......can someone with the AirRaid or AF1 please verify this - if true - I'm ordering one tonight!!
Lucky F-150 owners (if above is accurate) - with the '05 GT Mustang - you HAVE to run a custom tune with the CAI as the Ford ECU cannot adjust it's parameters enough to prevent a lean a/f mixture and throwing CEL codes.........
Originally Posted by Biggziff
I don't believe it for a second. Every test I've read says the mileage and power goes down..the only thing that goes up is the noise level.
Well ... I recently put the AF1 on my truck and can certainly feel a difference without changing tune from 87 octane. Yes I have a tuner ... but currently set to only compensate for the gears.
The narrowed down 2 choices are good ones in my book. I don't think anybody can tell a difference in felt power between the two. AirRaid is proven for a longer time with widespread usage as AF1 is just now starting to get delivered to people that have been waiting months to receive.
Thanks eveyone for the feedback...interesting comments.....makes me wonder what the folks at AirRaid are talking about by claiming such large gains.....would be easy to prove/disprove....anyone been to the dyno with this mod yet?
On my '05 GT Mustang with the 4.6 3v (same heads) what we are finding is that a tune alone (91 octane) will get you some gains (approx. 10rwhp) but when a high flow intake is added the gains are quite dramatic...in the range of 25rwhp gains with the tune/CAI combo. Many of the members have dyno'd and posted slips to prove the increase. I personally have the JLT/SCTExcalibrator set up and it is a HUGH difference over the stock intake with no tune.
Back to reality with the 5.4 though - it just seems to good to be true that you could add the amount of hp that they are claiming (which would indicate an much improved air flow) with out triggering CEL's for a "lean" condition.....unless the F-150 ECU can compensate better than the GT ECU can compensate for free'r flowing intake which I doubt - but am new to the F-150 world and perhaps their ECU's are more forgiving???
Doesn't seem to be any real data to prove it out. I bought a Diablo tuner for mine..there is real data that these help.
Don't expect big peak torque gains, but there will be some extra HP at the high end, but 22 RWHP is very optimistic. 5-10 is probably more in the ballpark.
Interesting Article About CAI's
Originally Posted by HotLap
Hey BZ - too bad you can't borrow an intake from someone and temp install - just to see what the combo of Tune with vs Tune w/o intake feels like.....would be curious to see if the 5.4 3V would react like the Mustang's are with the CAI/Tune combo.
Like others have said, if Ford left 22rwhp (something like 40-50 at the crank) on the table, then they're doing a crappy job at this game. I can see a little increase at WOT if you've also installed a free flowing exhaust, but everything has it's price
I can believe that Ford left a substantial amount of power untapped. First any production vehicle is a compromise. Not every F150 buyer cares about maximum power; some want smooth and quiet. Federal regulations have noise limits that affect intake and exhaust and who knows what else. If an example is needed, check out the Mustang Cobra. There were many posts on how just removing a restrictor, needed to keep noise down, in the intake tract added significant ( not positive but seem to remember 20hp) at the rear wheels. ( yes I know they are blown etc, but on Ford's hot rod they did leave alot on the table).
My '01 Lincoln LS V8 Sport had the same type of intake (couldn't even hear if the engine was running) I added an aftermarket DPG intake and it added (dyno tested) 15rwhp - then adding the Magnaflow exhaust added about that much again....in IMO - the car sounded much more like a performace engine (which it was) and was a lot more fun to drive with the extra hp and being able to hear the engine!
For the record what is the difference between the '04 2v 5.4 and the '05 3v 5.4....any claimed increase in hp or torque with the extra intake valve?
