Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-23-2005, 10:15 PM
drumrod drumrod is offline
Garage is empty, add now
drumrod is starting off with a positive reputation.
Econo king pins
Hi All, I'm building a 27 T using a 1966 Econo front axle. Not quite on the road yet. Just saw an add for some really neat looking kingpins for 61 to 63 econo spindles from Total Performance and wondered what the difference would be between the early spindles and my 66 spindles.
  #2 (permalink)
Old 05-24-2005, 09:55 AM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
early has spacer bushings, and a differant lock bolt.
later has spacer bearings, and the lock bolt can be made to work.
a word of warning, there are problems with the lock bolt groove in some sets of pins. the groove is machined too big, allowing the pin to move in the axel. this causes premature wear in the axel itself. once the axel is worn, no way to fix it.
  #3 (permalink)
Old 05-24-2005, 10:01 PM
Thanks for the info....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
