Actual Weights 2005 Supercab XLT 4x2
Here are the actual weights on a CAT scale of my truck with the following specifications:
2005 F150 Supercab XLT 144.5" WB 4x2
Exterior: Dark Toreador Red
Interior: Flint
Pkg 507A
5.4L V-8
255/65R16 OWL A/S
3.73 L/S Axle
Trailer Tow Pkg
Fog Lamps
Keyless Entry Keypad
Dealer Installed Options
Ford Bedliner
Ford Black Step Bars
7050 GVWR
15000 GCWR
9500 Tow Rating
CAT Scale Weights (With full 27.0 Gal Tank):
Total Tare - 5400 lb
Steer - 3000 lb
Drive - 2400 lb
Interior: Flint
Pkg 507A
5.4L V-8
255/65R16 OWL A/S
3.73 L/S Axle
Trailer Tow Pkg
Fog Lamps
Ford Bedliner
7050 GVWR
15000 GCWR
9500 Tow Rating
Steer - 3000 lb
Drive - 2400 lb
Ford lists your curb weight at 5169 and your payload at 1820.
By your measures, the weight is 5400 and payload is 1650.
Very interesting.
If you take a gallon of gas to be 6.5 lbs, that's 175.5 lbs, which deduct from your payload. Actual weight of gas varies, and also depends on temperature.
1820-1650=170 lbs, which is RIGHT on the money.
I guess Ford's numbers add up. No real surprise there. I've found Ford to be the most forthcoming and straightforward of the truck manufacturers when dealing with published numbers like that. They don't seem to screw around with the numbers, like other manufacturers.
Very interesting.
