You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I run 12 lbs of boost on my 2004 ford lighting with long tube headers, granateli mass air senor,flow master mufflers, accufad throttle body, had it dyno at romar last week,400 hp and414 lb's of torgue at rear wheels; is that good or not, my biablos sport tune with max fuel added,i had a a-f of 13-69 have to get custom tune
I'm gathering that your A/F ratios were 13.69, and that is way too lean for a blown application. Something around 12.0 A/F ratio is good and safe under boost.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
What he said. Richening it up will probably cost you a few hp, but will keep it alive longer.
How good the numbers are depends on several things. Are they corrected, and if so are they SAE or STD? My truck did 374/445 SAE with long tubes/exhaust and a drop in filter.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
i also have the 5.6L but with a whipple supercharger...... its runing on 13 lbs of boost.... but i´m only doing 405hp at 4750rpm........ something is going wrong??
it has shorty headers
3" exhaust tubes
deltachip.... diablo sport
crane cams.
titanium valvesprings
bigger valves..
magnaflow muffler...
generally speaking the air fuel mixture should be ajusted toward the rich side, a slightly rich condition means more powder and actually helps cool the combustion not less powder, like silver streak said,
My 04 makes 412HP and 502 Ft/Lb of torque at 12 pounds of boost. Your HP seems fine, but your torque is a little low. I agree that 13.6 A/F is uncomfortably lean. Get your chip re-burned for a 11.8 to 12.3 A/F and your truck will be happier. In my opinion long tubes out perform shorties
__________________
The point of life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn out, screaming "....HOLY ****!....WHAT A RIDE!
I bought the truck last summer and have yet to get to the track. The truck is a daily driver (22,000 miles in the last 11 months) and will never see much track time. Anyway, now that I have the mods I wanted in place, I’ll probably hit the local 1/8 mile a couple of times for grins. The closest ¼ mile is over two hours away and just not worth the drive to me.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
