You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
got a cutting torch today. i was in burlington getting some pool supplies, and i stopped into a pawn shop and saw a victor cutting torch set, used but not that bad of shape. asked the guy how much and he said 60 bucks. steal. he didnt know what somthing like that ran, but i tested it on a set of tanks he had, and it all worked, so i just got to get some gas now.
sounds like a good deal. You gonna leave it acetyline, or switch to propane? That setup works pretty good on propane too.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
the regulator and all that are the same, you just need a propane tip. I generally run at 15 psi for the propane, and 40 for the oxygen. I also use a #1 tip. The #2 is too big and takes out too much material.
__________________
