Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-20-2005, 08:25 PM
unluckylow's Avatar
unluckylow unluckylow is offline
Garage is empty, add now
unluckylow is starting off with a positive reputation.
Bio diesel/Fry oil
I was doing a lot of reading on this forum and a few of the others on alternative fuel choices. I am cinsidering running my truck with two tanks one carring vegi oil and the other with diesel. I was talking to the guys at griesel company ( they make tanks and filter systems http://www.greasel.com/ for our trucks) Will a 7.3 run straight off of 100% vegi oil? I know people run straight bio diesel in farm equipment but if I shut the truck off with the diesel tank and keep the vegi oil heated I shouldnt have any problems with it clogging injectors as long as I filtered it good before running in the truck. Any one doing this feel free to commet. I would like whoever wants to put there 2 cents out there go for it.Thanks
__________________
2000 Ford F-250 SC longbed 4x4, manual trans, converted manual transfer case
Mods: Gauges, Predator programmer 80HP setting, Banks 4'' exhaust, HX crossover line, 4'' lift, 35x12.5 Nitto AT, firestone rideright airbags and custom traction bars, duel shocks up front and steering stabilizer, AIH delete, wicked wheel, SB air intake and filter.
  #2 (permalink)
Old 05-20-2005, 08:49 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
1996 Ford F-250
My Garage
444dieselrod is gaining momentum as a positive member of FTE.
The '96 in my sig was bought just for this. I have modified the fuel system slightly, so that my setup will be almost automatic, and idiot proof. THe name fordnut74 will bring you ALOT of result on this, he is a wealth of knowledge.
here is a link to my pics, you can see some of the mods on the fuel system.
http://community.webshots.com/album/344490187dlVbvS
Straight WVO has to be heated to run properly, it can be mixed, up to a 75/25 mix oil/#2, in the stock tank, and run in the warmer minths. This week I will be starting to mix mine on the '96 I finaly have some oil filtered out that I am happy with.
Bio can be run with no mods, but it is harder to make and a lil more expensive then WVO
Diesel Rod
__________________
'96 F250, Reg Cab 7.3 PSD, Auto, 4x4, XLT.
'97 F250, Ext Cab 7.3 PSD, Auto, 4x4, XLT.
'96 F250, Crew Cab 7.3 PSD, 5-SPD, 4x4, XLT.
'99 Jetta TDI, 5-SPD
'87 359 Peterbilt SHORT HOOD, 36" sleeper. 13 speed, 425 intercooled Cat.
  #3 (permalink)
Old 05-21-2005, 06:30 PM
StevensPoint StevensPoint is offline
StevensPoint is starting off with a positive reputation.
Check out this link to read about my setup. I have now logged nearly 29,000 miles on vegoil with no problems.
http://www.ford-trucks.com/forums/sh...ight=fryer+oil
  #4 (permalink)
Old 05-22-2005, 03:40 PM
t.j.g.'s Avatar
t.j.g. t.j.g. is offline
t.j.g. is starting off with a positive reputation.
http://forums.biodieselnow.com/forum.asp?FORUM_ID=3
here a link that shows you how to make biodiesiel
good info itis pretty easy to to
i did a couple of test batches and succefully made my own biodiesel cost sbout 80 cents per gallon to make
can dump it right into fuel tank with out any problems
__________________
2000 psd c/c , open air intake , 4" sraight pipe , no cat ,
diablo sport chip , gtp38r b.b. turbo , 76,000 m , tank mod
Tags
60, conversion, diesel, ford, fry, fryer, kit, liter, mods, oil, run, suv, tanks, truck, turck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
