New F250 - need ideas tires lift - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-20-2005, 01:13 PM
Drake12 Drake12 is offline
Drake12 is starting off with a positive reputation.
Question New F250 - need ideas tires lift
Will be getting a new F250 6.0L this year at some point and want some ideas on tires and a lift. Probably end up with 17" Weld Racing wheels 8.5 or 10" wide. Want a nice ride with the lift/leveling kit. Whatever it takes to make 35" tires not rub and look nice. Thinking BFG 315's or something there abouts. Would a 3.5" leveling kit work ok? What type kit would work and ride the best?
Just looking for some ideas so I can start looking for these parts.
Thanks
Old 05-20-2005, 01:32 PM
Danko Danko is offline
Danko is starting off with a positive reputation.
No way you need different wheels or lifts to make 315's work. I just picked up my 2005 XLT F250 V-10 6 speed and there is plenty of room up front for 315's and probably enough in back for the 37/12.5 x 17's I want on there. I am going to use the stock rims but since I am not driving this truck much I may just put 315's on back for now and then just before snow falls, I will move them up front and add the 37's to the rear. BFG 37's are about 36" and the Goodyear GSA 37's are 36.8". TireRack.com shows all those specs and prices and are great to work with and charge no sales tax and shipping is modest. Go to their site and forget inputting info about your vehicle. Go to search by tires and plug in 315/70 x 17's and it will show you what is available, including their prices. I think only one BFG type right now. Then click on "specs" and it will give load limit, diam., section width, etc.
Old 05-20-2005, 01:36 PM
fordfast fordfast is offline
fordfast is starting off with a positive reputation.
I put a leveling kit in mine with M/T 17x9 classic locks with M/T Dick Cepec 35s, they look awsome but rub sometimes.
I will do a superlift 4 inch soon with the front skid plate.
If your going with 35s put at least a 4 inch lift under truck.
Old 05-20-2005, 01:47 PM
fordfast, WHY do your 35's rub? It has to be offset is pushing them out where there is contact????? I have measured my brand new 2WD F250 and do not see how a 35" diameter tire can rub front or back and a neighbor has 315/75 x 16's on his and they clear by a LOT, front and back and at full turn.
Old 05-20-2005, 02:08 PM
When I turn hard and hit bump they rub, not bad but annoying.
I also had to remove front mud flaps, they rubbed when turning. I`m going to try molded ones in front.
Old 05-20-2005, 02:18 PM
Thnx but that is when they rub. Why besides the turning are they rubbing? Do the wheels you are using bring them outboard? Are they an unusually wide tread width? Somehow I picture both those wheels and the tires as being wider than what most of us would use if we got "35's."
Old 05-21-2005, 10:21 AM
The rims are M/T classic lock 17x9, dont know offset.
Tires are M/T Dick Cepek radial F-C 2, 35x12.5OR17LT`s.
Old 05-24-2005, 02:00 AM
tyners3 tyners3 is offline
tyners3 is starting off with a positive reputation.
I run 33" BFG all-terrains on 16.5x10 Centerline Tracker wheels (unknown backspacing). These are on my stock 2004 F250 CC SB 6.0. The passenger front tire rubs on the front valance during hard right turns. I am having a 6" Skyjacker Z-link coilover lift installe dthis week to run 35's with no rubbing.
Old 05-24-2005, 08:00 AM
I think it is the wheel offset and not the tire diameter causing the rubbing.
Old 05-24-2005, 06:55 PM
fn250's Avatar
fn250 fn250 is offline
fn250 is starting off with a positive reputation.
Danko depends on the year of your truck. I have an '03 2wd with 6" of lift and 35's fit and rub valance slighty at full lock. On 05's it seems that 35's will fit with a slight lift/leveling kit. Check Yeti's gallery, I think he has a pick of a stock 5.4l SD with X Code leafs (tallest stock leaf spring and lightest engine) and 35's do not fit a stock SD. 05 may be different, so before preaching that 35's fit, we should proly verify year of the truck.
Old 05-24-2005, 07:39 PM
wkbrdr wkbrdr is offline
wkbrdr is starting off with a positive reputation.
Look in my gallery at my new F250. I went 6" on 315's (35's) without any rubbing. In my opinion it is the most proportional looking for these trucks. I am running 17x10 welds. When you lift it, no matter how high you go, look into aftermarket rear leaves. I cannot say enough good about mine...
leveling kit questions and advice 02 Stroker 1999 - 2003 7.3L Power Stroke Diesel 37 03-12-2013 02:53 PM
Lift kit for 35" tires on F250 Jayybird 1999 to 2016 Super Duty 11 07-16-2011 02:07 AM
expedition lift blackhullpirate Expedition & Navigator 1 10-16-2009 08:09 AM
For those with 4" lift kits PowerstrokeJunkie 1999 to 2016 Super Duty 6 03-12-2006 06:55 PM
Need pics and inputs for lifted 94.5-97 PSD's... I_wanna_PSD 1994.5 - 1997 7.3L Power Stroke Diesel 7 12-08-2004 05:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
