You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My 1992 Ranger 2.3L runs fine at cold start-up, but after a few minutes it begins to sputter and run like on only two cylinders. It smells rich and sounds like a helicopter. The fuel pump, filter, and MAF sensor have been changed. New plugs and wires have been installed, and coils tested. What could this be?
Pull the diagnostic codes. Check the fuel pressure... Is the fuel mileage down a WHOLE lot? Did this happen 'all of a sudden' or develop over time?
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Codes are spout circut open, low voltage to EGR, and loss of dual plug control, which have been showing for a long time. Fuel pressure is good, and yes mileage is WAY down. Had a similar problem at higher RPMs and the new MAF sensor cured it for a short time.
