83 ford ranger 4x4 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
83 ford ranger 4x4
Old 05-19-2005, 05:38 PM
chamelion chamelion is offline
chamelion is starting off with a positive reputation.
Question 83 ford ranger 4x4
Just bought used 83 ranger 4x4 2.8 liter bringing it home the aluminum timing gear separated in the middle, rebuilding these parts, can I put a 5spd trans in this rig and what might be involved in this upgrade? Also there is a suspicious hole in the front of the block behind the timing cover about 10 a clock, 2" from center of upper timing gear shaft, about the size of 16-18 gauge wire, is this an oil port for the timing gears? Not familiar with this engine, Anyone with with experiences with this motor would be appreciated, thanks
Will an 88 ranger engine fit my 83? tyco85 Ranger & B-Series 2 10-29-2008 09:09 AM
83 Ranger - Rear End Gearing BlueOvalLover Ranger & B-Series 6 05-19-2008 06:19 AM
change transmission bigg1975 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 05-29-2006 02:32 PM
3.83 gears Hank85713 Ranger & B-Series 1 08-29-2003 07:25 PM
Biggest tire in stock axles oldblue18 Ranger & B-Series 2 02-01-2001 05:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
