Headers
Headers
Anybody know any tricks to keeping headers tight?
85 F150 w/95 302HO crate, new Ford truck SS headers. I found them loose at 6000mi. I was thinking of gettin SS allen head cap screws, I don't guess SS will cause a problem with heads, but I don't know. If the SS screws don't keep em' tight, it'll sure make tightening easier.
There must be a way.
thanks,
Moe
Houston
thanks,
Moe
Houston
Headers
2 thoughts come to mind:
1. What kind of gaskets are you using? Get good, do it once..... And are you retorqueing after a day or so? The heat will shift things around a bit, right off the bat.
2. Do you have a straight block and headers? I had experinced a repeat offender, always blowing out the exhaust gaskets dut to fastener loosening. Found out that the exhaust was warped just so slightly, and as soon as the machine shop planed them out, the offender went "quietly" away.
Good luck,
Kevco
Good luck,
Kevco
Headers
try looking at a summit catalog, i see them in there all the time, the bolt kit runs around $35.00 but here is how they work, the hex head bolt has a grove in it and they give you a retainer and a snap lock for each bolt the reainer fts up against the tube then the snap lock keeps the retainer and bolt from moving , theyalso have a allen head inside the hex head..
they do work good , i use them on my race car, they have not came loose yet, been on there for about 2 years..here is summits phone # 1-800-230-3030.. good luck
DR Smith
12-24-2013 04:25 PM
mark460
15
02-18-2007 03:41 AM
