bleeding anti lock brakes??? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-17-2005, 11:31 PM
bully 515 bully 515 is offline
bully 515 is starting off with a positive reputation.
hey guys! how hard is it to bleed anti lock brakes? just put on front pads and the brakes are soft, i'll be changing the rear soon and would like to bleed the system. thanks...
Old 05-18-2005, 01:20 AM
SoCal01 SoCal01 is offline
SoCal01 is starting off with a positive reputation.
it's no different than a non-abs system. make sure to do it in this order:
right rear
left rear
right front
left front
oh, also keep an eye on the reservoir and don't let it get too low... and don't leave the cap off it because brake fluid loves moisture and it pulls it out of the air.
good luck!
Old 05-18-2005, 08:48 AM
thanks alot i'll be doing that later...
Old 05-18-2005, 10:20 PM
Matt03Expy's Avatar
Matt03Expy Matt03Expy is offline
Matt03Expy is starting off with a positive reputation.
Check this site out. I made one of these and it works great.
Pressure Brake Bleeder
Old 05-20-2005, 06:53 PM
just want to thank everyone for their help, i bled my brakes and everything is tight this board saved me so much $$$$$!!!!
Old 05-20-2005, 10:35 PM
F150'89 F150'89 is offline
F150'89 is starting off with a positive reputation.
Matt03Expy, I like your power brake bleader and its on the list to build. I replaced my clutch master cylinder today and now have a spare cap that will be made into a adapter also.
CHECK BRAKE SYSTEM WARNING Randy Aikman 2015+ F150 2 05-18-2016 01:38 AM
Check Brake System Warning Randy Aikman Tennessee Chapter 1 05-16-2016 11:21 PM
2009 F150 King Ranch Randy Aikman 2009 - 2014 F150 0 05-15-2016 07:23 PM
bleeding brakes friskyjake 1994.5 - 1997 7.3L Power Stroke Diesel 13 03-07-2014 07:43 PM
88 F150 Bleeding brakes question sumdumgai 1987 - 1996 F150 & Larger F-Series Trucks 1 06-13-2009 05:02 PM
Tags
2006, antilock, bleeding, brakes, f150, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
