4.6l romeo/windsor differences? - Ford Truck Enthusiasts Forums
Old 05-16-2005, 07:58 PM
98stepside 98stepside is offline
98stepside is starting off with a positive reputation.
Just wondering the differences between a windsor 4.6 and a romeo 4.6. I know the VIN number 6 is windsor and W is Romeo but what is the actual differences, just the assembly plants?
Just curious
Old 05-16-2005, 10:10 PM
jcstratt jcstratt is offline
jcstratt is starting off with a positive reputation.
The differences run a little deeper than that. Here are a few:
REP (Romeo Engine Plant) motors have 11 bolts on the left valve cover, WEP (Windsor Engine Plant) motors have 13.
Camshafts sprockets are retained differently between the two and the TDC camshaft alignments are different.
Water pump hose under the intake manifold is retained differently, REP is clamp, WEP is metal tube and nut.
REP Crankshaft main caps have 2 main cap bolts, 2 jack screws, 2 side bolts. WEP crank main caps have bolts, dowel pins, but no jackscrews.
Number of thrust washers on the last crank journal are different.
Crank main cap torque specs are different.
There may be other differences, these are just a few that I know of.
Old 05-17-2005, 12:46 AM
DOHCmarauder's Avatar
DOHCmarauder DOHCmarauder is offline
DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.
Weird, huh???? Ford makes an engine line and calls it a modular for the ease of interchangeability and then makes two different versions.
The flywheel to crankshaft bolt #'s are different also....(5 vs. 6 ?)
Old 03-22-2009, 06:00 PM
Zorks Zorks is offline
Zorks is starting off with a positive reputation.
other differances
I am working on a swap out and came across alot of info. flywheel/flexplate is 6 or 8 on the windsor, Most comman to be the 8. romeo used 11 differnt heads. so on so forth. check this link for more details on it. it changed my mind on what I was going to do with my 98.
Rebuilding the Ford 4.6L SOHC Engine, Doug Anderson, Engine Builder, April 2002
that lists a ton of changes on the 2.
and thats Ford for you. nvr what you have grown to love about them and nvr the same twice. makes life fun as a gear head.
4.6 winsor to romeo swap coonhntr15 Modular V8 (4.6L, 5.4L) 1 03-23-2015 05:45 PM
Windsor vs Romeo? Redneckryder 1997 - 2003 F150 6 11-08-2014 08:24 PM
Romeo or windsor foreverfordtrucks 1997 - 2003 F150 7 08-02-2013 06:03 AM
4.6L Windsor vs. Romeo Engines fireball69 Modular V8 (4.6L, 5.4L) 1 02-22-2004 07:44 PM
4.6 romeo / 4.6 windsor radar_ridr Modular V8 (4.6L, 5.4L) 2 03-15-2003 08:39 AM
Tags
46, 46l, 98, cap, differences, engine, flexplate, ford, main, rep, romeo, specs, torque, wep, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
